Error (10481)
Geehrter Beitragender II
1.222Aufrufe
I generated a IP module from SOPC builder, and added the module source files in my project.
When I compile it, I get the following error :
Error (10481): VHDL Use Clause error at XXX : design library YYY does not contain primary unit ZZZ
My SOPC builder IP modules is in Verilog, and my top-level file is in VHDL. I found in the QIP file that the IP design is mapped to a library, using the "-library" syntax. So I instantiated the IP module mapped to this library name in my top-level, and also declared the same library.
In Quartus, I added the QIP file in my project, and also declared the library name in the project librairies.
Any idea what can cause this error ?
0 Antworten
Antworten
