17256 ディスカッション
Error 10500
名誉コントリビューター II
5,860件の閲覧回数
Hi, i have problems with my vhdl code.
This is the code:
LIBRARY IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
use ieee.numeric_std.all;
ENTITY brake_var IS
port (
clk : in std_logic;
reset : in std_logic;
chip_select : in std_logic;
writedata : in std_logic_vector (31 downto 0);
write_n : in std_logic;
address : in std_logic;
readdata : out std_logic_vector (31 downto 0);
out_port1 : out std_logic_vector (7 downto 0);
out_port2 : out std_logic_vector (7 downto 0));
END brake_var;
ARCHITECTURE brake_system OF brake_var IS
signal D : unsigned (31 downto 0); -- distance d'arrêt
signal v : unsigned (31 downto 0); -- vitesse du véhicule
signal Dmax : unsigned (31 downto 0); -- vitesse max (danger)
signal tb : std_logic;
signal brake : std_logic;
BEGIN
readdata <= std_logic_vector(D) when address = '0' else std_logic_vector(v);
registers: PROCESS (clk, reset)
BEGIN
if reset = '0' then
D <= (others =>'0');
v <= (others =>'0');
elsif clk'event and clk = '1' then
if chip_select ='1' and write_n = '0' then
if address = '0' then
D (31 downto 0) <= unsigned(writedata (31 downto 0));
else v (15 downto 0) <= unsigned(writedata (15 downto 0));
end if;
end if;
end if;
END PROCESS;
distance : PROCESS (clk,reset)
begin
if reset = '0' then
elsif clk'event and clk='1' then
D(31 downto 0) <= (v(15 downto 0)*3)/10 + (v(15 downto 0)*v(15 downto 0))/100;
else
end if;
END PROCESS;
tableau_de_bord : PROCESS (clk,reset)
begin
if reset = '0' then
tb <= '0';
tb <= '0' when D < Dmax else
'1' when D > Dmax;
end if;
end process;
frein : PROCESS (clk,reset)
begin
if reset = '0' then
brake <= '0';
brake <= '0' when tb = '0' else
'1' when tb ='1';-- freinage
end if;
END PROCESS;
out_port1 <= (others=> tb);
out_port2 <= (others=> brake);
END brake_system ;
And the error :
Error (10500): VHDL syntax error at ppp.vhd(61) near text "when"; expecting ";"
Error (10500): VHDL syntax error at ppp.vhd(71) near text "when"; expecting ";"
Error: Quartus II 32-bit Analyze Current File was unsuccessful. 2 errors, 0 warnings
Error: Peak virtual memory: 329 megabytes
Error: Processing ended: Sun May 25 19:34:03 2014
Error: Elapsed time: 00:00:03
Error: Total CPU time (on all processors): 00:00:03
Help me please it's urgent.
0 件の賞賛
47 返答(返信)
名誉コントリビューター II
2,877件の閲覧回数
you are mixing up between combinatorial conditional syntax and process based one.
do not use when inside the process.
名誉コントリビューター II
2,877件の閲覧回数
i could you plz be more specific ?
i used if instead of when but i got this error :
Can't infer register for because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "D[0]" at ppp.vhd(47) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "D[1]" at ppp.vhd(47) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "D[2]" at ppp.vhd(47) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "D[3]" at ppp.vhd(47) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "D[4]" at ppp.vhd(47) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "D[5]" at ppp.vhd(47) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "D[6]" at ppp.vhd(47) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "D[7]" at ppp.vhd(47) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "D[8]" at ppp.vhd(47) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "D[9]" at ppp.vhd(47) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "D[10]" at ppp.vhd(47) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "D[11]" at ppp.vhd(47) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "D[12]" at ppp.vhd(47) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "D[13]" at ppp.vhd(47) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "D[14]" at ppp.vhd(47) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "D[15]" at ppp.vhd(47) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "D[16]" at ppp.vhd(47) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "D[17]" at ppp.vhd(47) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "D[18]" at ppp.vhd(47) because it does not hold its value outside the clock edge
Error (12152): Can't elaborate user hierarchy "projetppp:inst|brake_var:ppp_inst"
Error: Quartus II 32-bit Analysis & Synthesis was unsuccessful. 20 errors, 7 warnings
Error: Peak virtual memory: 371 megabytes
Error: Processing ended: Sun May 25 19:59:59 2014
Error: Elapsed time: 00:00:10
Error: Total CPU time (on all processors): 00:00:10
Error (293001): Quartus II Full Compilation was unsuccessful. 22 errors, 7 warnings
名誉コントリビューター II
2,877件の閲覧回数
you have many other errors e.g. multiple drive on D.
you have to be careful as I don't think your brake system will brake
名誉コントリビューター II
2,877件の閲覧回数
do you have some advices ?
because i'm a little bit lost :/ :/
and thank you very much :)
名誉コントリビューター II
2,877件の閲覧回数
Error: Quartus II 32-bit Analysis & Synthesis was unsuccessful. 20 errors, 6 warnings
Error: Processing ended: Sun May 25 20:16:52 2014
Error: Elapsed time: 00:00:14
Error: Total CPU time (on all processors): 00:00:12
Error (293001): Quartus II Full Compilation was unsuccessful. 22 errors, 6 warnings
here is what i got when i changed the code like this :
LIBRARY IEEE;
ENTITY brake_var IS
port (
clk : in std_logic;
END brake_var;
BEGIN
BEGIN
if reset = '0' then
end if;
end if;
end if;
END PROCESS;
begin
if reset = '0' then
else
end if;
END PROCESS;
begin
if reset = '0' then
tb <= '0';
if
D < Dmax then tb <= '0' ;
else
tb <='1' ;
end if ;
end if;
end process;
begin
if reset = '0' then
brake <= '0';
if tb = '0'
then brake <= '0';
else brake <='1'; -- freinage
end if;
end if;
END PROCESS;
END brake_system ;
名誉コントリビューター II
2,877件の閲覧回数
LIBRARY IEEE;
ENTITY brake_var IS
port (
clk : in std_logic;
END brake_var;
BEGIN
BEGIN
if reset = '0' then
end if;
end if;
end if;
END PROCESS;
begin
if reset = '0' then
else
end if;
END PROCESS;
begin
if reset = '0' then
tb <= '0';
if
else
tb <='1' ;
end if ;
end if;
end process;
begin
if reset = '0' then
brake <= '0';
if tb = '0'
then brake <= '0';
end if;
end if;
END PROCESS;
END brake_system ;
名誉コントリビューター II
2,877件の閲覧回数
instead of
tableau_de_bord : PROCESS (clk,reset) begin if reset = '0' then tb <= '0'; elsif clk'event and clk='1' then tb <= '0' when D < Dmax else '1' when D > Dmax; end if; end process;
something like this below:
tableau_de_bord : PROCESS (clk,reset) begin if reset = '0' then tb <= '0'; elsif clk'event and clk='1' then if D < Dmax then tb <= '0'; elsif D > Dmax then tb <= '1'; end if; end if; end process;
and the same for other process
名誉コントリビューター II
2,877件の閲覧回数
i did that but i got 22 errors like this one :Error (10818): Can't infer register for "D[0]" at ppp.vhd(47) because it does not hold its value outside the clock edge
do you have any idea what should i change next ?
名誉コントリビューター II
2,877件の閲覧回数
D is wrong all over. It is assigned in two processes. You need to make your mind what should D be.
also note you should not use else for the if of clock edge as it is not meant to be combinatorial.
名誉コントリビューター II
2,877件の閲覧回数
D is a breaking distance with D formula is D = (v(means speed) x3 )/10 + v²/100
and i didn't understood => "you should not use else for the if of clock edge as it is not meant to be combinatorial."
thank you very much
名誉コントリビューター II
2,877件の閲覧回数
In that case assign to D what you are after in one process only as below. Later you need to sort out your divisions.
comment out as below
distance : PROCESS (clk,reset) begin if reset = '0' then D <= (others =>'0'); elsif clk'event and clk='1' then D(31 downto 0) <= (v(15 downto 0)*3)/10 + (v(15 downto 0)*v(15 downto 0))/100; --else --D <= (others =>'0'); end if; END PROCESS;
名誉コントリビューター II
2,877件の閲覧回数
i got this
Error (10028): Can't resolve multiple constant drivers for net "D[31]" at ppp.vhd(47)
and many similars errors :p
(sorry for that amount of question but i need to fix it for tomorrow :( :( : ( )
thank you very much
名誉コントリビューター II
2,877件の閲覧回数
I already told you that D must be assigned in one process only. So the assignment in first process means two drivers(you can't drive a bus with two drivers!).
If you want D to have different assignments then include all that in set of statements inside one process.
名誉コントリビューター II
2,877件の閲覧回数
so do you have any suggestion how i should change that ?
i will be very greatfull :p :)
名誉コントリビューター II
2,877件の閲覧回数
You will need to tell us what your design is meant to do before diving in any coding. Reverse engineering is painfully hard let alone if code is wrong
名誉コントリビューター II
2,877件の閲覧回数
co design of and anti collision system made for cars ;
with D the distance between the object and Dmax is the max tolerable distance
v is the car's speed
tb is an indicator that indicate is yes or no there is and object
and brake is for the abs
LIBRARY IEEE;
ENTITY brake_var IS
port (
clk : in std_logic;
END brake_var;
BEGIN
BEGIN
if reset = '0' then
end if;
end if;
end if;
END PROCESS;
begin
if reset = '0' then
tb <= '0';
brake <= '0';
--else
if D > Dmax then
tb <= '0';
elsif D < Dmax then
tb <= '1';
end if;
if tb = '0' then
brake <= '0';
elsif tb = '1' then
brake <= '1';
end if;
end if;
END PROCESS;
END brake_system ;
i putted it all in the same process but i got the same errors :/ :/ i'm more and more confused
名誉コントリビューター II
2,877件の閲覧回数
For now D is the problem. D is the distance and according to your code you are getting it from writedata.
but in second process you are calculating it. So which one is right?
名誉コントリビューター II
2,877件の閲覧回数
i thought that i would take v from writedata and calculate then D no ?
LIBRARY IEEE;
ENTITY brake_var IS
port (
clk : in std_logic;
END brake_var;
BEGIN
BEGIN
if reset = '0' then
tb <= '0';
brake <= '0';
--D (31 downto 0) <= unsigned(writedata (31 downto 0));
end if;
end if;
if D > Dmax then
tb <= '0';
elsif D < Dmax then
tb <= '1';
end if;
if tb = '0' then
brake <= '0';
elsif tb = '1' then
brake <= '1';
end if;
end if;
END PROCESS;
END brake_system ;
gave me no errors but 94 warnings :D
名誉コントリビューター II
2,877件の閲覧回数
you still got D assigned at reset in first process????
名誉コントリビューター II
2,824件の閲覧回数
now you confused me. It is one process. May be it is better.
can you put tags on code i.e. type [{code}] your code [{/code}]
but without the curly brackets.
返信
