17252 Discussions
Error: Compiler Error, not able to generate hardware
Can someone help me with this issue:
[........hello_world]$ aoc -v device/hello_world.cl -o bin/hello_world.aocx --board a10gx
aoc: Environment checks are completed successfully.
aoc: If necessary for the compile, your BAK files will be cached here: /var/tmp/aocl/fpga
You are now compiling the full flow!!
aoc: Selected target board a10gx
aoc: Running OpenCL parser....
aoc: OpenCL parser completed successfully.
aoc: Compiling....
aoc: Linking with IP library ...
Checking if memory usage is larger than 100%
aoc: First stage compilation completed successfully.
Error: Error opening /home/fpga/Downloads/hello_world/bin/hello_world/ip/kernel_system/kernel_system_avs_kernel_sender_cra_cra_ring.ip.
Error: Error opening /home/fpga/Downloads/hello_world/bin/hello_world/ip/kernel_system/kernel_system_avs_reorder_const_cra_cra_ring.ip.
Error: Error opening /home/fpga/Downloads/hello_world/bin/hello_world/ip/kernel_system/kernel_system_avs_mem_writestream_cra_cra_ring.ip.
Error: Error opening /home/fpga/Downloads/hello_world/bin/hello_world/ip/kernel_system/kernel_system_boardtest_system.ip.
Error: Error opening /home/fpga/Downloads/hello_world/bin/hello_world/ip/kernel_system/kernel_system_avs_kernel_receiver_cra_cra_ring.ip.
Error: Error opening /home/fpga/Downloads/hello_world/bin/hello_world/ip/kernel_system/kernel_system_avs_nop_cra_cra_ring.ip.
Error: Error opening /home/fpga/Downloads/hello_world/bin/hello_world/ip/kernel_system/kernel_system_avs_mem_readstream_cra_cra_ring.ip.
Error: Error opening /home/fpga/Downloads/hello_world/bin/hello_world/ip/kernel_system/kernel_system_avs_mem_read_writestream_cra_cra_ring.ip.
Error: Quartus Prime IP Generation Tool was unsuccessful. 8 errors, 0 warnings
Error (293001): Quartus Prime Full Compilation was unsuccessful. 10 errors, 0 warnings
Error: Flow compile (for project /home/fpga/Downloads/hello_world/bin/hello_world/top) was not successful
Error: ERROR: Error(s) found while running an executable. See report file(s) for error message(s). Message log indicates which executable was run last.
Error (23031): Evaluation of Tcl script /home/fpga/intelFPGA_pro/17.0/quartus/common/tcl/internal/qsh_flow.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 17 errors, 0 warnings
The error message seems pretty clear; either aoc does not have write access to the folder you are using, or your storage is unstable/full.
You were right about the storage being unstable.
HRZ, I tried it on another storage device and I'm having the same issue.
--- Quote Start ---
--- Quote End ---
Reported the same issue here https://www.alteraforum.com/forum/showthread.php?t=56472&page=2 and asked the other poster if he had come up with solution. Have you fixed a problem with these ip files missing?
