17252 Discussions
Kernel Emulation Device not found
Hi everyone. I managed to compile a kernel in emulation mode. Now I was trying to run it from my host program and I can find an Altera Platform but when I try to retrieve the devices it can't find any.
I have looked on the Intel FPGA pdf for the configuration and they say to add a DWORD on "HKEY_LOCAL_MACHINE\SOFTWARE\Altera\Boards" with the name as the full path to the dll file of the board which in my case is: terasic_apb_16_0_mmd.dll. When I do this the program outputs:
Error: Could not load board library C:\altera\16.0\hld\board\terasic\windows64\bin\terasic_apb_16_0_mmd.dllWarning: Cannot find any Altera board libraries. No Altera devices will be loaded. Error: Could not load board libraries successfully.
But I have set up all enviroment paths and so on. Why is this happening?!
Thank you
