17249 Discussions
Error: Top-level design entity "bai3" is undefined
Can You help me correct this problem in this code below:
module PWM( Ton,T,clk,Output_PWM);
input clk;
output Output_PWM;
input [7:0] Ton;
input [7:0] T;
reg Output_PWM;
integer a,i;
initial
begin
a = 0;
i = 0;
end
always@( posedge clk)
begin
if(i == 99999)
begin
i = 0;
a= a +1;
if(a <= T)
begin
if(a<= Ton)
Output_PWM = 1;
else
Output_PWM = 0;
end
else
a = 0;
end
end
endmodule
Probably your project name is "bai3" but your top level module is "PWM". Go to Assigments->Settings and go to Top level entity and select PWM. Click OK and compile again.
add "bai3.v" to project and check if module name is bai3.v
add "bai3.v" to project and check if module name is "bai3" and set top module "bai3"
