Error in compling
FTecc
When I compile this program I get the errors in the photo. Can someone help me?
The program is a demo file and I didn't make any changes. The manufacturer has assured me that it is fully functional.
Use of first quartus 18.0.
I tried also with quartus II and I have the same problem
RRomano001
Please provide more detail, which board which demo design which vendor?
FTecc
yes, the board is Altera De4 board equipped with Fpga Stratix IV EP4SGX230KF40C2.
The external card is terasic SDI- HSMC p0039.
I download the demo project by official site.
RRomano001
from main board and add on I suppose demo is
PCIe Image Process Application.
I am no more using stratix, require subscription, mine expired more than 10yr ago, hope someone else can help you.
sstrell
The design was probably created in an older version of Quartus that used those settings for Signal Tap. The easiest thing to try would be to open the project, open the .stp file, and save it as a new .stp file. Then in Quartus, go to Assignments-> Settings-> Signal Tap and point to the new file. That should fix things. Then try to recompile.
#iwork4intel
