17250 Discussions
Error in "Run as -> Nios II Modelsim" using Eclipse SBT
Hello:
I'm using Quartus 11.1 under Ubuntu 11.10.
I've been following this(altera.com/support/examples/nios2/exm-simulating-niosii.html) tutorial, trying to simulate a system created with Qsys.
Everything goes fine, until I finally try to simulate the system in modelsim. When I execute "Run as -> Nios II Modelsim" I get the following error:
Failed Executing: make sim SPD=/home/daniel/Documentos/universidad/Proyecto/tutorial_diseno/an351_design/niosii_system_tb.spd ELF=/home/daniel/Documentos/universidad/Proyecto/tutorial_diseno/an351_design/software/hello_world_an351/hello_world_an351.elf ENABLE_VSIM_GUI=1 VSIM_DIR=/home/daniel/altera/11.1/modelsim_ase/linuxaloem return code: 2Checking the Nios II console, the error seems to come from the file sh_jar.sh:
Post-processing to create mem_init/niosii_system_ram.hex... elf2hex /home/daniel/Documentos/universidad/Proyecto/tutorial_diseno/an351_design/software/hello_world_an351/hello_world_an351.elf 0x00010000 0x0001ffff --width=32 --little-endian-mem --create-lanes=0 mem_init/niosii_system_ram.hex /home/daniel/altera/11.1/nios2eds/bin/sh_jar.sh: 2: Bad substitution make: *** Error 2And the content of that file is:
# !/bin/sh FILEPATH=${0//\\/\/} _this_script=$(cd ${FILEPATH%*} && echo $(pwd 2>/dev/null)/${FILEPATH##*/}) _this_script_dir=$(dirname ${_this_script}) CMD="$0" perl -I ${_this_script_dir} ${_this_script_dir}/pl_jar.pl "$CMD" "$@" ~ As suggested in some forums, I tried to change the first line with "#!/bin/bash", but it didn't work.
It seems that the problem is located in the second line: "FILEPATH=${0//\\/\/}"
Has anybody else encountered with this problem? I'd really appreciate any help on this issue
Finally, I found an answer in this post: alteraforum.com/forum/showthread.php?t=32760
One point that we have found with Ubuntu. Most things do work well, however the issue that you mention in your note is very similar to some other .sh issues that we have seen. On Ubuntu, this is commonly resolved by changing the symbolic link for /bin/sh from /bin/dash to /bin/bash: sudo rm /bin/sh sudo ln -s /bin/bash /bin/sh Dash and Bash have a slightly different syntax, and that gets us around most issues.
This solution worked for me :)
Did both of answers you provided, none worked.
Any other solutions?
ABinO1
I faced the same issue, I solve it by modifying the path shown to run modelsim , so instead of calling modelsim ae , I make it call modelsim ase
