Error: (vcom-7)
Hiii
i'm having same problem in this thead
http://www.alteraforum.com/forum/showthread.php?t=26060
my case is that i'm used to compiling through gui not via cmd
but whenever i select compile all or ceven compile selected .. nothing happened
so when i wrote the compiling command in the transcript window i got this error which is
(Error: (vcom-7) Failed to open design unit file "TB.vhd" in read mode)
i also got the same error message whenever i compile any other file was already compiled
Note:
when i opened task manager to close running thread i found# of vcom.exe processes =# of my compiling trials
I would be so happy for your reply..
thanks,
Niveen..
ther is another thing
when i tried to close "TB.vhd" i got this message
(can't read "data(realized)": no such variable)
is there any relation between this and my problem
thanks,
Niveen
i tried to make a work arround by creating new file then copy and paste my code in it to be compiled then
but i got this waring with no compilation too
"Warning: (vcom-6) -- Waiting for lock by "....@...., pid = 768
". Lockfile is "....../work/_lock".
appreciating all your help..
Niveen..
