17247 Discussions
Error when setting password - Feature not implemented or unavailable under current execution privile
alexislms
Valued Contributor I
jtagconfig to run jtagd: Error when setting password - Feature not implemented or unavailable under current execution privilege level
Please advise. The whole behavior of jtagd and jtagconfig is obscure and we don't understand anything, there is no help, no documentation regarding these binaries.
alexislms
@sstrell That's exactly what I've done. There is no valid reason to run any of the jtag* commands as root.
After trying again and again after reboots and all, it has stopped returning this error.
It would still be good to know why I got this error message.
sstrell
It looks like you are trying to set up a JTAG server and need a password.  Put -h after jtagconfig for info.
All the available options correlate to options in the GUI so check the Programmer user guide:
https://www.intel.com/content/www/us/en/docs/programmable/683039/22-3/the-jtagconfig-debugging-tool.html
alexislms
"need a password" for what?
The help doesn't really help...
JTAG Server Configuration
Usage: jtagconfig [--enum]
jtagconfig --add <type> <port> [<name>]
jtagconfig --remove <cable>
jtagconfig --getparam <cable> <param>
jtagconfig --setparam <cable> <param> <value>
jtagconfig --define <jtagid> <name> <irlength>
jtagconfig --undefine <jtagid> <name> <irlength>
jtagconfig --defined
jtagconfig --addserver <server> <password>
jtagconfig --enableremote <password>
jtagconfig --disableremote
jtagconfig --version
jtagconfig --help
jtagconfig --extrahelp
For more details use jtagconfig --extrahelp
And for enableremote:
--enableremote Tells the JTAG server to allow connections from remote
<password> machines. These machines must specify the same password
when connecting.
As you can see in the screenshot, the password is provided "mypass".
Then, why do I get this error message?
As you can imagine, I follow this page: https://www.intel.com/content/www/us/en/docs/programmable/683472/22-4/installing-and-configuring-a-local-jtag.html
sstrell
You run --enableremote on the machine you want to act as the JTAG server, setting the password that others will use to connect to it.  On other machines that want to connect to this machine as a server, they use --addserver, setting the address of the server and the password that was set.
As for the error, perhaps you have to run it as sudo.
alexislms
NurAiman_M_Intel
You need to run it in administrator mode to avoid the error.
Aiman
NurAiman_M_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
