17268 Discussions
Errors for using Modelsim AXI BFM for Altera
I try the Altera example for using Mentor axis vip example under C:\altera\15.0\ip\altera\mentor_vip_ae\axi3\qsys-examples\ex1_back_to_back_sv. Following the guide. But I got the errors bellow while running vsim :
The tools:version I used:
1. Quartus II 64bit 15.0.0 Full version
2.Modelsim Altera 10.3d 32bit.
Is there anything wrong with the dlls or something else? I searched the web and did not find anything matched this(one mentioned the license,but I think the later full version should have license for using vip) Thanks!
logs:
ModelSim ALTERA 10.3d
vsim -t ps $ELAB_OPTIONS -L work -L work_lib -L rst_controller -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L cycloneiv_hssi_ver -L cycloneiv_pcie_hip_ver -L cycloneiv_ver $TOP_LEVEL_NAME -mvchome $env(QUARTUS_ROOTDIR)/../ip/altera/mentor_vip_ae/common -c
# vsim
# Start time: 00:19:30 on May 13,2016
# Loading C:\Users\mou\AppData\Local\Temp\mou@WIN-728EN2N2I93_dpi_4492\win32pe_gcc-4.2.1\export_tramp.dll
# Loading sv_std.std
# Loading work.top
# Loading work.QUESTA_MVC
# Loading work.mgc_axi_pkg
# Loading work.master_test_program_sv_unit
# Loading work.slave_test_program_sv_unit
# Loading work.monitor_test_program_sv_unit
# Loading work.ex1_back_to_back_sv
# Loading work.mgc_axi_inline_monitor_sv_unit
# Loading work.mgc_axi_monitor_sv_unit
# Loading work.mgc_common_axi_sv_unit
# Loading work.mgc_axi_master_sv_unit
# Loading work.mgc_axi_slave_sv_unit
# Loading rst_controller.altera_reset_controller
# Loading rst_controller.altera_reset_synchronizer
# Compiling C:\Users\mou\AppData\Local\Temp\mou@WIN-728EN2N2I93_dpi_4492\win32pe_gcc-4.2.1\exportwrapper.c
# Loading C:\Users\mou\AppData\Local\Temp\mou@WIN-728EN2N2I93_dpi_4492\win32pe_gcc-4.2.1\dpi_auto_compile.dll
# Loading C:\altera\15.0\quartus/../ip/altera/mentor_vip_ae/common/questa_mvc_core/win32_gcc-4.2.1/libaxi_IN_SystemVerilog_MTI_full.dll
# ** Error: (vsim-3193) Load of "C:\altera\15.0\quartus/../ip/altera/mentor_vip_ae/common/questa_mvc_core/win32_gcc-4.2.1/libaxi_IN_SystemVerilog_MTI_full.dll" failed: DLL dependent library not found.
# ** Error: (vsim-8649) Initialization function 'axi_IN_SystemVerilog_load' not found.
