17268 Discussions
Failed to generate Legacy License
MKuśm
Hello. I downloaded Quartus software, but it calls for license at startup.
After trying to get license here: https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/licensing/lic-choose.html
I get this email:
There is an issue in generating the license for this provided NIC/Host ID: ****************   Please check your NIC/Host ID and try again. If you still encounter problems, please contact our customer support.   Intel FPGA Applications 24/7 Technical Support: https://www.intel.com/content/www/us/en/programmable/mysupport   DISCLAIMER: This is an automated email. Please do not reply to this email.
How can I start using Quartus?
sstrell
What version/edition of Quartus are you trying to get a license for?
#iwork4intel
MKuśm
Quartus Prime 16.1
sstrell
Lite (no license needed), Standard, or Pro?
As that page says, for newer versions of Quartus, you need to use the self-service licensing center here (after logging into intel.com):
https://fpgasupport.intel.com/Licensing/license/index.html
#iwork4intel
MKuśm
This way it says: You do not have any products for which you can create a new license.
Contact Customer Service for assistance.
sstrell
Yes, you have to purchase a license first, giving them your MAC address (which I recommend you erase from your original post), and then use the SSLC to actually generate the license file.
#iwork4intel
MKuśm
I assumed that Quartus is a free software.
I bought Terasic ADC-SoC development board with ALTERA Cyclone V.
Do I need licensed Quartus for programming this development board?
sstrell
It depends on the functionality you need. Lite edition is free and supports Cyclone V, but you may want/need features only available in Standard. See the comparison here:
https://www.intel.com/content/www/us/en/software/programmable/quartus-prime/download.html
#iwork4intel
Zawani_M_Intel
Thanks sstrell!!
Hi MKuśm,
Do answer from our Intel team, sstrell address your inquiry?
Please do let us know if anything else we can help?
Wani
Zawani_M_Intel
In anticipating the issue has been resolved, the case will set as close-pending.
Thanks!
Wani
