Avisos
17268 Discusiones
Failed to start in Programmer
Junyong
Principiante
6.483 Vistas
Hi all,
I'm trying to start with Programmer after compilation.
When I hit "Start" button, the progress bar stopped at 0% (Failed).
Are there any ways to check error messages regarding the above issue?
Etiquetas (1)
0 kudos
1 Solución
RichardTanSY_Altera
6.399 Vistas
Could you please go through the steps provided in the user guide and check if there is any configuration or device compatible issue?
Link: <https://www.intel.com/content/www/us/en/docs/programmable/683039/23-1/basic-device-configuration-steps.html>
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
Ver la solución en mensaje original publicado
18 Respuestas
sstrell
Colaborador Distinguido III
6.477 Vistas
Errors/warnings would appear in the usual Messages window of the main Quartus window.  Check there.
Junyong
Principiante
6.473 Vistas
Thank you for reply.
I checked Quartus Prime Pro's main screen, but there was no error message regarding the issue I'm trying to resolve.
Best,
sstrell
6.412 Vistas
On the System tab there maybe?
RichardTanSY_Altera
6.400 Vistas
Richard Tan
Junyong
Principiante
6.322 Vistas
Hi Richard,
I'm stil trying to resolve above issue.
My device is Intel® Stratix® 10 TX Signal Integrity Development Kit.
The example design file is Stratix10_PCIeGen3x8_DMA_18_0.
After compilation, I'm trying to go further at "Programmer" stage.
When I clicked "Auto Detect", then pop-up says I should select my device from the list below.
I think my device is not here, so what should I do to select my device correctly?
FvM
6.292 Vistas
according to user guide, the Stratix 10 device is 1ST280EY2. The programmer however doesn't care for speed code, so any of the three selections should work. More important that the correct device is select in your project, can be expected for examples shipped with board.
Junyong
Principiante
6.234 Vistas
Thank you for your reply, FvM.
After selecting the device "1ST280EY2", I have a pop-up warning with the message below:
I'm wondering why the message showed up. I already modify the Instance with Stratix 10:1ST280EY2F55E1VG. But, the compiled stuff has the device of 1SX280LU3F50S1.
Can I know how to change the device name in the project?
RichardTanSY_Altera
6.261 Vistas
Does the FvM's response help in answer your inquiry?
Richard Tan​
Junyong
Principiante
6.234 Vistas
Hi Richard,
Thank you for your reply. It helped, but my problem isn't resolved yet. Could you please refer to my reply above?
RichardTanSY_Altera
6.219 Vistas
I noticed that your project has selected the device "Stratix 10:1ST280EY2F55E1VG." Could you please try cleaning the project (Project > Clean Project) and then recompiling it?
Also, I'd like to ask if you might be using the old .sof file that was generated for the previous device by any chance?
Richard Tan
Junyong
Principiante
6.212 Vistas
Thank you, Richard.
I'm tyring to compile the project after cleaning it.
By the way, I have a question regarding the JTAG ID code.
When I program the project, I got a message that "Cant' configure deivce. Expected JTAG IC code 0x4321D0DD for device2, but found JTAG ID code 0x323D0DD. Make sure the location of the target device on the circuit board matches the device's location in the device chain in the chain description file (.cdf)."
Honestly, I have no idea how to handle above issue.
FvM
6.189 Vistas
your latest posts suggests that you are trying to program the wrong device in JTAG chain, MAX V rather than Stratix 10. Although it should be able to select the correct device in programmer, I suggest to remove MAX V from device chain by respective DIP switches. User manual tells how.
Junyong
Principiante
6.172 Vistas
After removing the MAX V from the device chain, I tried to program the project again.
I had a message that File "Generated .sof" is incomplete - Power management settings are not set up appropriately on VID part.
So, should I modify the power management setting? I have no idea why this happend, becuase I just downloaded, compiled, and programmed the example PAR file on my dev kit.
sstrell
6.138 Vistas
You probably need to follow the settings here and in the linked power management user guide:
https://www.intel.com/content/www/us/en/support/programmable/articles/000076902.html?wapkw=stratix%2010%20vid%20settings
Junyong
Principiante
6.040 Vistas
Thank you for your reply. It was helpful to me.
RichardTanSY_Altera
5.925 Vistas
Do you need further help in regards to this case?
Richard Tan
Junyong
Principiante
5.885 Vistas
RichardTanSY_Altera
5.884 Vistas
I'm glad to hear that your question has been addressed. Now, I will transition this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Thank you and have a great day!
Richard Tan
Responder
