17268 Discussions
Fast I/O registers in Bidirection IO
Hi, I am trying to improve the IO timing by using fast IO registers.
However, how could I set a proper register when facing a bidirection IO?
Thank you~!
You have three settings at your disposal:
FAST_INPUT_REGISTER
FAST_OUTPUT_REGISTER
FAST_OUTPUT_ENABLE_REGISTER
For a bidirectional IO, you can set any or all of these to TRUE for the pin in question. Your design must of course actually support the function:
1 - The pin must be driven directly by a register output with no combinatorial logic.
2 - The input must be fed directly to a register with no combinatorial logic
3 - If you choose to use a fast output enable then the output enable for the pin must be driven directly by a register.
Jake
--- Quote Start ---
--- Quote End ---
Thank you for your rapidly reply!
When using a bidirection IO, the output and input are not directly fed by a register, but via a buffer.
Even if my output reg before bidirection buffer is register pipelined so that there is certainly no combinatorial logic. I think course 1 and 2 are not met because of the buffer itself.
Only the buffer's enable reg could be set in this condition?
thank you ag~
I should be more clear. Besides the buffer ... there can be nothing between the pin and register.
Jake
--- Quote Start ---
Jake
--- Quote End ---
I think I've been thinking too much to waht you've said just now, hehe~
And so according to this, I just set and apply the Fast IO register constrains directly to the Bidir IO pin, it will do work.
Thank you very much!
