17255 Discussions
Fatal Error: Segment Violation at (nil)
JobvW
Débutant
2 936 Visites
Hello, I am trying to synthesize my vhdl code, but when I run synthesize in Quartus prime I get this error. The only thing I can find is that there is a patch for Quartus prime pro, but I am using Quartus prime lite.
In my vhdl code I am trying to write a vga controller.
I am using a MAX10 10M50DAF484C7G fpga.
If anybody can point me in the right direction I would be grateful, thanks in advance.
Problem Details
Error:
*** Fatal Error: Segment Violation at (nil)
Module: quartus_map
Stack Trace:
   0x1a228a: Netlist::ProcessGlobals() + 0x3f6 (synth_vrfx)
   0x1a6282: Netlist::Polish() + 0xa0 (synth_vrfx)
   0x2bcd5c: VhdlEntityDecl::CoreElaborate(VhdlSecondaryUnit*, char const*, VhdlBlockConfiguration*) + 0x518 (synth_vrfx)
   0x2c2409: VhdlEntityDecl::Elaborate(char const*, Array*, Map*, VhdlBlockConfiguration*) + 0x403 (synth_vrfx)
   0x146283: VRFX_VERIFIC_VHDL_ELABORATOR::elaborate(BASEX_ELABORATE_INFO*) + 0x1df (synth_vrfx)
   0x13b4e9: VRFX_ELABORATOR::elaborate(BASEX_ELABORATE_INFO*) + 0xb9 (synth_vrfx)
   0x1795ce: SGN_FN_LIB::elaborate(BASEX_ELAB_INFO_CORE*) const + 0x18e (synth_sgn)
   0x181a8e: SGN_FN_LIB::start_vrf_flow() const + 0xe (synth_sgn)
   0x1826bd: SGN_FN_LIB::start(SGN_WRAPPER_INFO*) + 0xb6d (synth_sgn)
   0x1870e9: SGN_EXTRACTOR::single_module_extraction(HDB_INSTANCE_NAME*, HDB_ENTITY*, SGN_WRAPPER_INFO*) const + 0x119 (synth_sgn)
   0x18fa61: SGN_EXTRACTOR::recursive_extraction(HDB_INSTANCE_NAME*, SGN_WRAPPER_INFO*, char const*) + 0xf1 (synth_sgn)
   0x190c7e: SGN_EXTRACTOR::recurse_into_newly_extracted_netlist(HDB_ENTITY*, HDB_INSTANCE_NAME*, unsigned long, SGN_WRAPPER_INFO*) + 0x65e (synth_sgn)
   0x18fc8c: SGN_EXTRACTOR::recursive_extraction(HDB_INSTANCE_NAME*, SGN_WRAPPER_INFO*, char const*) + 0x31c (synth_sgn)
   0x19bd60: SGN_EXTRACTOR::extract() + 0x2b0 (synth_sgn)
   0x1a65d0: sgn_qic_full(CMP_FACADE*, std::vector<std::string, std::allocator<std::string> >&, std::vector<double, std::allocator<double> >&) + 0x250 (synth_sgn)
    0x19433: qsyn_execute_sgn(CMP_FACADE*, std::vector<std::string, std::allocator<std::string> >&, std::string const&, THR_NAMED_PIPE*, THR_NAMED_PIPE*) + 0x173 (quartus_map)
    0x34649: QSYN_FRAMEWORK::execute_core(THR_NAMED_PIPE*, THR_NAMED_PIPE*) + 0x219 (quartus_map)
    0x3734a: QSYN_FRAMEWORK::execute() + 0x89a (quartus_map)
    0x1ae88: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x639 (comp_qexe)
    0x2b4a1: qsyn_main(int, char const**) + 0x151 (quartus_map)
    0x3ee30: msg_main_thread(void*) + 0x10 (ccl_msg)
     0x5acc: thr_final_wrapper + 0xc (ccl_thr)
    0x3eeef: msg_thread_wrapper(void* (*)(void*), void*) + 0x62 (ccl_msg)
     0x9f9c: mem_thread_wrapper(void* (*)(void*), void*) + 0x5c (ccl_mem)
     0x91d9: err_thread_wrapper(void* (*)(void*), void*) + 0x27 (ccl_err)
     0x5b0f: thr_thread_wrapper + 0x15 (ccl_thr)
    0x40ea1: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xb2 (ccl_msg)
    0x2338a: __libc_start_main + 0x8a (c.so.6)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: linux64
OS name: Arch Linux
OS version:
Quartus Prime Information
Address bits: 64
Version: 21.1.1
Build: 850
Edition: Lite Edition
0 Compliments
ventt
Employé
2 714 Visites
From the latest update from the engineering team:
They found the line that's causing the issue:
In vhdl/common_pkg.vhd, the definition of function c_t_char_array_init, if "x(32-1 DOWNTO 0) := STD_LOGIC_VECTOR(TO_UNSIGNED(I, 32));" is commented out, the program will be able to compile successfully.
They were able to resolve the IE with RTL changes and provide the workaround. The two files modified are total.vhd and common_pkg.vhd. Essentially they moved the function declaration from the package to the file where the function is used, which fixed the problem.
Kindly check your email for the workaround. Thanks.
Ven Ting
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey
Voir la solution dans l'envoi d'origine
0 Compliments
10 Réponses
ventt
Employé
2 901 Visites
Thanks for attaching the files. However, can you archive your project, so that I can restore the complete project and ensure that no files are missing?
In Quartus, Open the project > Project > Archive Project.
Afterwards, you may upload the compressed .qar file. Thanks.
You may check out the link on archiving projects:
https://www.intel.com/content/www/us/en/docs/programmable/683475/19-4/archiving-projects.html
Ven Ting
0 Compliments
JobvW
Débutant
2 883 Visites
Thanks for your reply, I created the archive altho as expected I got the same error message, so not all files are included in the archive.
This was the error message after the archiving:
Project archive created; however, Analysis and Elaboration (or Analysis and Synthesis for export database) was not successful. As a result, some files could not be archived.
Greetings,
Job van Wee
0 Compliments
ventt
Employé
2 872 Visites
Thanks for attaching the file.
Can you send the patch that you found for Quartus Prime Pro, so that I can investigate more on this error?
Best Regards.
Ven Ting
0 Compliments
JobvW
Débutant
2 865 Visites
0 Compliments
ventt
Employé
2 844 Visites
Thanks for attaching the link.
I will check this with the Engineering Team.
Ven Ting
0 Compliments
ventt
Employé
2 784 Visites
FYI, Engineering Team requires some time to investigate further to the Fatal Error. Kindly stay tuned with us.
Ven Ting
0 Compliments
ventt
Employé
2 715 Visites
Ven Ting
0 Compliments
SyafieqS
Employé
2 712 Visites
Hi Job,
May I know if the workaround is satisfiable?
Let me know if there is any update or other concern on this
0 Compliments
JobvW
Débutant
2 583 Visites
Yes, Thanks!!
So in the problem was that i tried to use a function in a package that gets declared in the same package.
Thank you very much!!
0 Compliments
SyafieqS
Employé
2 655 Visites
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 10/10 survey
0 Compliments
Répondre
