I'm wiring basically long delay lines using a lot of NOT gates. When I exceed 7600 gates in a row (without any flip flops or clocks), Quartus won't compile my project anymore, but I just get the following error: *** Fatal Error: Stack Overflow Module: quartus_map.exe Lock in use: 9 Stack Trace: 0x4758e: STA_TDC_CLOCK_INTERFACE::has_a_clock + 0x2e8e (TSM_STA) 0x47943: STA_TDC_CLOCK_INTERFACE::has_a_clock + 0x3243 (TSM_STA) 0x47943: STA_TDC_CLOCK_INTERFACE::has_a_clock + 0x3243 (TSM_STA) .......(approximately 30 times the same line repeated) End-trace Quartus II 64-Bit Version 11.1 Build 173 11/01/2011 SJ Full Version My Verilog program looks basically like this: assign delay_wire[1] = ~delay_wire[0]; assign delay_wire[2] = ~delay_wire[1]; .... Please help me with this problem! Thank you, DavidLink Copied
wow, that is an interesting feat
STA must be static timing analyzer, so you might turn off timing driven synthesis and maybe physical synthesis - anything that has to do with analyzing the timing of your logic have you tried cascading blocks of say 1000 inverters instead of putting it all in one source file? unfortunately i don't think this a difficult thing for Altera to support because the delay will not be compensated over PVT, so you may have trouble getting a proper fix. either way you could file an SR at http://mysupport.altera.com- Mark as New
Thank you.
I changed the settings and got rid of everything with clocks. Now I can implement more inverters without errors, but still get the same message when I introduce more than 20000 inverters. So it has to be some kind of software issue with Quartus, right?- Mark as New
yes, it must be. but like i said its in a bit of a grey area of support
curious, what is your delay goal?
