17266 ディスカッション
Firmware revision 0x000a on channel 0 is not supported
Lorne_K_Intel
従業員
1,460件の閲覧回数
quartus 20.2 build 50.60/11/2020
Firmware revision 0x000a on channel 0 is not supported  when loading e-tile toolkit.
E-tile parameter change to 10G implementation caused e-tile toolkit to not load.
Hundreds of e-tile example designs were built and loaded successfully until this configuration.
0 件の賞賛
3 返答(返信)
Deshi_Intel
モデレーター
1,438件の閲覧回数
2 Warning found in EHIP IP
Deshi_Intel
モデレーター
1,436件の閲覧回数
  1. Can you share full screenshot of the error message ?
  2. When you mentioned E-tile toolkit, are you referring to transceiver toolkit ?
  3. May I know are you using Intel FPGA dev kit board or your own custom board ?
  4. Your quartus design FPGA OPN shown you are using ES silicon device - VGS1
  • ES silicon device is not meant to support all feature in long run.
    • Do you have S10 production device to try out ?
  1. I noticed you have some warning in EHIP IP setting. Can you clean up the warning and then retry toolkit ?
  2. Can you also try out toolkit with latest Quartus version v20.4. Compile design with v20.4 and open toolkit in v20.4
dlim
Deshi_Intel
モデレーター
1,405件の閲覧回数
HI,
I am setting this case to closure since I haven't hear back from you for more than 2 weeks.
Hopefully things is working on your side.
Feel free to post new forum thread if you still required help in future.
Deshi
返信
