Initially I flashed the CPLD - MAX V 5M1270Z using USB Blaster and Quartus prime it was successful
Then, I was trying to reprogram CPLD using JTAG - JAM STAPL interface, where it gave me error code-11 "Device Verify Failure" so I tried to reflash the CPLD using USB Blaster in quartus prime software it showed me the below error.
Error (209015): Can't configure device. Expected JTAG ID code 0x020A30DD for device 1, but found JTAG ID code 0xFFFFFFFF. Make sure the location of the target device on the circuit board matches the device's location in the device chain in the Chain Description File (.cdf).
Can anyone help me understand whether I am getting this error as flashing using JTAG has corrupted some JTAG ID code?? and how to now flash the software to CPLD as I am stuck
P.S: Setup was not disturbed, hence it is unlikely the issue with USB cables, TIA!!
連結已複製
Yes, I tried with the power cycle and even reconnecting the blaster multiple times,
Sometimes the error code 35 was observed but then after restarting the PC again shows the same error code (209015)
I probed the TDO pin on DSO to check whether it is stuck at some logic level.
But that was not the case I was able to see the signal getting toggled, when there is programming command from Quartus-Prime through Blaster
We are not able to establish communication after power cycle. How can we make sure if device is damage ? Please help us with any steps, process to verify it.
VCCIO voltage is 3.3V & VCCINT voltage is 1.8V
These are regulated voltages and generated from power rails.
Is there any way to make sure if device is damaged ? Like device could draw more current draw, something like that
