17267 Discussions
Force a reg not to use M9K but logic
Hi
I do use M9K for ROM tables and this works fine
I also have to use quite some latches since I works as pipeline
The problem are when I do use latches then QuartusII on some of the latches do use M9K and other a logic , then I do not have enough M9K for ROM
I have tried different combination with ramstyle="logic" in my verilog
(* ramstyle = "logic" *) reg [63:0] Block_out;
reg [63:0] Block_out /* synthesis ramstyle = "logic" */;
And still some of my reg do use M9K
Any hint?
There are different synthesis attributes to control RAM inference for memory arrays and for shift registers. Apparently your construct refers to the latter. http://www.alteraforum.com/forum/showthread.php?t=37702
That did the trick
Assignments -> settings -> analysis and synthesis settings -> more settings
"auto shift register placements". Change this to "off".
Thank you
A global assignment works too, of course. As in the linked thread, the assignment is often required for specific objects.
