17263 Discussions
Getting base of address of the IP's
HI, Is there a report where we can get the base address of the IP that we generated after compiling?
If you're talking about a Qsys system, yes -- you can view the address map in Qsys itself (on screen) or there are HTML datasheets generated when you generate the qsys system.
I think that is what you are asking about.
-Lance
yes, will check it out
The base address can actually view from the Qsys system, after the Qsys system is generated, In the c code, the base address is defined as IP_NAME_BASE. The IP_NAME is define in the Qsys system.
