17255 Discussions
HELLLP about DPI coding
Try to make a function generator by using DPI sin functions from C, however, error occurred
this is my whole sv code
package math_pkg;
//import dpi task C Name = SV function name
import "DPI-C" pure function real cos (input real rTheta);
import "DPI-C" pure function real sin (input real rTheta);
import "DPI-C" pure function real log (input real rVal);
import "DPI-C" pure function real log10 (input real rVal);
endpackage : math_pkg
Error (10170): Verilog HDL syntax error at math_pkg.sv(3) near text ""DPI-C"; expecting an identifier
what the heck is going on dude ??
DPI is for simulation, not for synthesis.
--- Quote Start ---
--- Quote End ---
Thank you for replying
I wonder why this is synthesis not simulation
Is there a way that I can use sine functions for synthesis in fpga?
then how to create a function generator with C languages ?
thankyou!
--- Quote Start ---
https://pdfs.semanticscholar.org/f523/c638e72ce7a9b068470510ba54d23bf715fb.pdf
--- Quote End ---
Thank you so much! this helps me a lot! , :)
Can I also ask a question the input/output declaration for a module?
for example
module slc3(
input logic [15:0] S,
input logic Clk, Reset, Run, Continue,
output logic [11:0] LED,
output logic [6:0] HEX0, HEX1, HEX2, HEX3,
output logic CE, UB, LB, OE, WE,
output logic [19:0] ADDR,
inout wire [15:0] Data //tristate buffers need to be of type wire
i see that all the input output are calculated in a binary form,
However , the input from the article suggestests a fraction number(like 0.45)
https://alteraforum.com/forum/attachment.php?attachmentid=13710&stc=1
if the result from sine wave is, for example, -0.52, should i express this in binary for the module 's output? and datatype of the output be like?(logic, real....) thanks!
I see you have a lot to learn about designing digital hardware. Everything in hardware binary. https://sestevenson.wordpress.com/introduction-to-fixed-point-representation/
