17268 Discussions
HLS support in Lite and Standard versions
Hello all!
I installed Quartus 17.1 Lite version (with the problems that I described here (https://www.alteraforum.com/forum/showthread.php?t=57953&p=235788)) and Standard version.
Operating System - Debian GNU / Linux 9
After installation, I did not find the hls/ directory.
In paragraph 1.2, "initializing the intel hls compiler environment" in the "intel high level synthesis (hls) compiler getting started guide" (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/hls/ug-hls-getting-started.pdf) says:
--- Quote Start ---
On Linux systems, initialize your environment as follows:a. In your terminal session, change directories to the hls directory in your Intel Quartus Prime installation directory.
For example, /home/<username>/intelFPGA_pro/17.1/hls
--- Quote End ---
Why there is no hls/ directory?
How to work with HLS in this case?
Thank you!
HLS is not supported in Lite version.You can use standard and pro version for HLS projects.
Refer
1.https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/hls/ug-hls-getting-started.pdf
2.https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/hls/ug-hls.pdf
In standard you may find HLS directory without examples folder.
In pro HLS directory with examples.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
--- Quote Start ---
Refer
Anand Raj Shankar
--- Quote End ---
After you have helped to fix another issue (https://www.alteraforum.com/forum/showthread.php?t=57953), the hls/ directory is in place even in Lite version :)
Now everything is fine!
Thank you!
--- Quote Start ---
Thank you!
--- Quote End ---
Sorry.
The issue is more tricky than I described first -- more info (https://www.alteraforum.com/forum/showthread.php?t=57953&p=235805#post235805)
