17267 Discussions
Hello, I would like to Display scroll the word 'DE10' or any word across the six seven segment display of my DE10-Lite board. I can not seem to get it working, would you be able to help me?
KRose13
//////////////////// SCROLLING DE10 ////////////////////////////////
module DE10_LITE_Default(
 input clock, reset,
 input HEX0, HEX1, HEX2, HEX3, //the 4 inputs for each display
 output a, b, c, d, e, f, g, dp, //the individual LED output for the seven segment along with the digital point
 output [3:0] an  // the 4 bit enable signal
localparam N = 18;
reg [N-1:0]count; //the 18 bit counter which allows us to multiplex at 1000Hz
always @ (posedge clock or posedge reset)
 begin
 if (reset)
  count <= 0;
 else
  count <= count + 1;
 end
reg [6:0]sseg_temp; //the 7 bit register to hold the data to output ==== Changed from 'reg' ====
reg [3:0]an_temp; //register for the 4 bit enable
always @ (*)
 begin
 case(count[N-1:N-2]) //using only the 2 MSB's of the counter
  2'b00 : //When the 2 MSB's are 00 enable the fourth display
  begin
   sseg = HEX0;
   an_temp = 4'b1110;
  end
  2'b01: //When the 2 MSB's are 01 enable the third display
  begin
   sseg = HEX1;
   an_temp = 4'b1101;
  end
  2'b10: //When the 2 MSB's are 10 enable the second display
  begin
   sseg = HEX2;
   an_temp = 4'b1011;
  end
  2'b11: //When the 2 MSB's are 11 enable the first display
  begin
   sseg = HEX3;
   an_temp = 4'b0111;
  end
 endcase
 end
assign an = an_temp;
reg [6:0] HEX_Display; // 7 bit register to hold the binary value of each input given
always @ (*)
 begin
 case(sseg)
  4'd0 : HEX_Display = 7'b0111111; //to display dash
  4'd1 : HEX_Display = 7'b0000001; //to display 0
  4'd2 : HEX_Display = 7'b1001111; //to display 1
  4'd3 : HEX_Display = 7'b0110000; //to display E
  4'd4 : HEX_Display = 7'b1000010; //to display d
  4'd5 : HEX_Display = 7'b0111111; //to display dash
  //4'd6 : sseg_temp = 7'b0000010; //to display 6
 // 4'd7 : sseg_temp = 7'b1111000; //to display 7
 // 4'd8 : sseg_temp = 7'b0000000; //to display 8
  //4'd9 : sseg_temp = 7'b0010000; //to display 9
  //default : sseg_temp = 7'b0111111; //dash
 endcase
 end
assign HEX_Display = {g, f, e, d, c, b, a} ; //concatenate the outputs to the register, this is just a more neat way of doing this.
// I could have done in the case statement: 4'd0 : {g, f, e, d, c, b, a} = 7'b1000000;
// its the same thing.. write however you like it
assign dp = 1'b1; //since the decimal point is not needed, all 4 of them are turned off
endmodule
RichardTanSY_Altera
Hi, you can try out this example tutorial first to get a hand of it.
FPGA Design with Verilog (7 segment)
Then you can learn to multiplex in the below link, though it is in VHDL code.
https://www.fpga4student.com/2017/09/vhdl-code-for-seven-segment-display.html
