Help with FFT mode
Hi guys, in my current setting i'm using a streaming mode FFT but thats just because it was the default setting. Another mode can help me get rid of serieus M4K-block issues. The system I have setup is like this:
An external ADC is hooked on my Altera DE-1 board. The serial output of this ADC is put in a 12-bit bus and than stacked in a FIFO of 2048 words. When the FIFO is full, the FFT is activated and get's the 2048 samples. When this is done the ADC is activated again.
Should I maybe use the burst, buffered burst mode of the FFT or just stick with streaming?
Thanks in advance!
--- Quote Start ---
Thanks in advance!
--- Quote End ---
I am no expert on current altera fft (but used it a decade ago ! when it was one mode only and I converted it to streaming mode) .
If indeed you can wait stopping the ADC then you can go for burst mode which requires minimum memory. If your ADC bursts are shorter than burst mode then you can go for buffer burst which uses some memory.
If on the other hand you must keep ADC running always then you need to use streaming mode in which case you don't need pre-buffering as it is done inside fft using a lot of memory.
To give you an idea about streaming that I did: I used two fft cores each running after the other plus memory for two frame buffering. first frame of input data was buffered completely then fft1 started meanwhile second frame was passed to its buffer. Once fft1 was done data was output and fft2 starts processing from its buffer while input passed to 1st buffer and so on. Now all this is done by choosing streaming mode avoiding all that trouble.
I'm getting very confused in how to use the FFT properly right now. I'm now using burst mode and a single output engine. I do get output from the FFT but when I use pythagoras on it (sqrt(real*real+imaginary*imaginary)) I get very high values. Sometimes with no audio input at all.
My adc puts in a binary number around 127 with silence and goes up to 4096 as full number.
Here is my code which is a state machine, which feeds the FFT. Please look at it and let me know what i'm doing wrong.
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; -------------------------------------- entity FFTStatemachine is port( clk,clk32mhz,reset,enable,deserializerdone: IN std_logic; enabledeserializer,writefifotestled,source_valid: OUT std_logic; fifoinput : IN STD_LOGIC_VECTOR (13 DOWNTO 0); fifooutput : OUT STD_LOGIC_VECTOR (13 DOWNTO 0); source_exp : OUT STD_LOGIC_VECTOR (5 DOWNTO 0); source_real : OUT STD_LOGIC_VECTOR (13 DOWNTO 0); source_imag : OUT STD_LOGIC_VECTOR (13 DOWNTO 0); source_error : OUT STD_LOGIC_VECTOR (1 DOWNTO 0); source_sop : OUT STD_LOGIC; source_eop :OUT STD_LOGIC ); end entity; -------------------------------------- architecture implementation of FFTStatemachine is component FFT is port ( clk : IN STD_LOGIC; reset_n : IN STD_LOGIC; inverse : IN STD_LOGIC; sink_valid : IN STD_LOGIC; sink_sop : IN STD_LOGIC; sink_eop : IN STD_LOGIC; sink_real : IN STD_LOGIC_VECTOR (13 DOWNTO 0); sink_imag : IN STD_LOGIC_VECTOR (13 DOWNTO 0); sink_error : IN STD_LOGIC_VECTOR (1 DOWNTO 0); source_ready : IN STD_LOGIC; sink_ready : OUT STD_LOGIC; source_error : OUT STD_LOGIC_VECTOR (1 DOWNTO 0); source_sop : OUT STD_LOGIC; source_eop : OUT STD_LOGIC; source_valid : OUT STD_LOGIC; source_exp : OUT STD_LOGIC_VECTOR (5 DOWNTO 0); source_real : OUT STD_LOGIC_VECTOR (13 DOWNTO 0); source_imag : OUT STD_LOGIC_VECTOR (13 DOWNTO 0) ); end component; component FIFO is port ( rdclk : IN STD_LOGIC ; wrempty : OUT STD_LOGIC ; wrfull : OUT STD_LOGIC ; q : OUT STD_LOGIC_VECTOR (13 DOWNTO 0); rdempty : OUT STD_LOGIC ; rdfull : OUT STD_LOGIC ; wrclk : IN STD_LOGIC ; wrreq : IN STD_LOGIC ; aclr : IN STD_LOGIC ; data : IN STD_LOGIC_VECTOR (13 DOWNTO 0); rdreq : IN STD_LOGIC ); end component; -- Signals & Variables -- ------------------------------------------------------------------- -- state definitions and signals ---------------------------------- ------------------------------------------------------------------- type state is ( Idle, WriteFIFO, FIFOLatency, Startreading, ReadFIFO, Finishreading, Finished ); signal present_state, next_state: state; signal enablefifolatencycounter: std_logic; signal enablefifosamplecounter: std_logic; signal FIFOlatencycounter: integer range 0 to 10:=0; signal fifocounter : integer range 0 to 3000:=0; signal done :std_logic; --FFT local input signals signal inverse : std_logic :='0'; signal sink_valid : std_logic; signal sink_sop : std_logic; signal sink_eop : std_logic; --signal sink_real : STD_LOGIC_VECTOR (11 DOWNTO 0); signal sink_imag : STD_LOGIC_VECTOR (13 DOWNTO 0):="00000000000000"; signal sink_error : STD_LOGIC_VECTOR (1 DOWNTO 0) :="00"; signal source_ready : STD_LOGIC; --FFT local output signals signal sink_ready : STD_LOGIC; --signal source_sop : STD_LOGIC; --signal source_eop : STD_LOGIC; --signal source_valid : STD_LOGIC; --FIFO local inputs signal enablewriting : STD_LOGIC; signal enablereading : STD_LOGIC; signal clearfifo : STD_LOGIC; --FIFO local outputs signal fifo_out :std_logic_vector (13 downto 0); signal readempty :std_logic; signal readfull :std_logic; signal writeempty :std_logic; signal writefull :std_logic; ---------------------------------------------------------------------- --PORTMAPS------------------------------------------------------------ ---------------------------------------------------------------------- begin FastFourierTransform: FFT PORT MAP (clk,reset,inverse,sink_valid,sink_sop,sink_eop,fifo_out,sink_imag,sink_error,source_ready,sink_ready,source_error,source_sop,source_eop,source_valid,source_exp,source_real,source_imag); FIFORAM : FIFO PORT MAP (clk,writeempty,writefull,fifo_out,readempty,readfull,clk32mhz,deserializerdone,clearfifo,fifoinput,enablereading); ------------------------------------------------------------------ -- sequential part of the statemachine ---------------------------- ------------------------------------------------------------------- fifooutput<=fifo_out; writefifotestled<=sink_ready; process(reset, clk, next_state) begin if (reset = '0') then clearfifo<='1'; present_state <= Idle; elsif (rising_edge(clk)) then clearfifo<='0'; present_state <= next_state; end if; end process; process(present_state,next_state, enable,sink_sop,fifocounter,done,writeempty,writefull,readempty,sink_ready,FIFOlatencycounter) begin case present_state is when Idle => if enable ='1' and writeempty = '1' then next_state <= WriteFIFO; else next_state <=Idle; end if; when WriteFIFO => if writefull ='1' then next_state <= FIFOlatency; else next_state <=WriteFIFO; end if; when FIFOlatency => if FIFOlatencycounter = 1 then next_state <= Startreading; else next_state <=FIFOlatency; end if; when Startreading => if sink_sop ='1' then next_state <= ReadFIFO; else next_state <=Startreading; end if; when ReadFIFO => if fifocounter = 511 then next_state <= Finishreading; else next_state <=ReadFIFO; end if; when Finishreading => if readempty ='1' then next_state <= Finished; else next_state <= Finishreading; end if; when Finished => if done = '1' and sink_ready = '1' then next_state <= Idle; else next_state <=Finished; end if; end case; end process; process(present_state,clk) begin case present_state is when Idle=> enablefifosamplecounter<='0'; enablefifolatencycounter<='0'; done <='0'; enabledeserializer<='0'; enablewriting <='0'; enablereading <='0'; sink_valid <='0'; sink_eop <='0'; sink_sop <='0'; source_ready<='1'; when WriteFIFO=> enablefifosamplecounter<='0'; enablefifolatencycounter<='0'; done <='0'; enabledeserializer<='1'; enablewriting <='1'; enablereading <='0'; sink_valid <='0'; sink_eop <='0'; sink_sop <='0'; source_ready<='1'; when FIFOLatency=> enablefifosamplecounter<='0'; enablefifolatencycounter<='1'; done <='0'; enabledeserializer<='0'; enablewriting <='0'; enablereading <='1'; sink_valid <='0'; sink_eop <='0'; sink_sop <='0'; source_ready<='1'; when Startreading=> enablefifosamplecounter<='1'; enablefifolatencycounter<='0'; done <='0'; enabledeserializer<='0'; enablewriting <='0'; enablereading <='1'; sink_valid <='1'; sink_eop <='0'; sink_sop <='1'; source_ready<='1'; when ReadFIFO=> enablefifosamplecounter<='1'; enablefifolatencycounter<='0'; done <='0'; enabledeserializer<='0'; enablewriting <='0'; enablereading <='1'; sink_valid <='1'; sink_eop <='0'; sink_sop <='0'; source_ready<='1'; when Finishreading=> enablefifosamplecounter<='1'; enablefifolatencycounter<='0'; done <='0'; enabledeserializer<='0'; enablewriting <='0'; enablereading <='1'; sink_valid <='1'; sink_eop <='1'; sink_sop <='0'; source_ready<='1'; when Finished=> enablefifosamplecounter<='0'; enablefifolatencycounter<='0'; done <='1'; enabledeserializer<='0'; enablewriting <='0'; enablereading <='0'; sink_valid <='0'; sink_eop <='0'; sink_sop <='0'; source_ready<='1'; end case; end process; process(clk, enablefifosamplecounter,fifocounter) begin if(rising_edge(clk))and enablefifosamplecounter = '1' then fifocounter <= fifocounter+1; end if; if enablefifosamplecounter = '0' then fifocounter <=0; end if; end process; process(clk,enablefifolatencycounter,FIFOlatencycounter) begin if(rising_edge(clk))and enablefifolatencycounter = '1' then fifolatencycounter<=fifolatencycounter + 1; end if; if enablefifolatencycounter= '0' then fifolatencycounter <=0; end if; end process; end architecture;
The best way to check fft output is use an independent model e.g. matlab fft:
y = fft(x,points);
then round it as per fft core.
The altera fft core wants you to use the output exponent to rescale the output for each block.
Also check that your adc input is of correct format(2's complement) and that indeed you are inputting the values you think. Check that input frame is exactly entering the fft as required without any extra zeros or duplicate samples across the whole frame...etc.
I'm not familier with Matlab. Never used it before but I will see if I can get that package. For now I would like to try that exponent output.
As far as I know I get a signed number out of the FFT, right? What should I do with the exponent number in combination with the real and imaginary output.
I have read the FFT manual....but I do not really understand.
By the way, the ADC gives out a straight binary of 12 bits, but I put 2 zero's in front of it and then put it in a 14 bit wide FFT. This will make it a signed binary.
Matlab may have free trial version. There is also has a free version called Octave. Or you may find other fft tools around.
Alternatively you can inject one sample in the frame(otherwise set to zeros) and you should get a cosine/sine wave output at a given frequency(depending on sample location within frame). You can also reverse that by inputting a sine wave then you get a nozero sample surrounded by zeros.
Scaling is well documented with example coding in the fft use guide. I don't really remember or know the details of the current core. I used to just shift divide my output by number of bits = exponent (as far as I remember). Note this is not a standard approach but done to the convenience of altera engineers, they have used internally a representation somewhere between 2's complement and standard floating point.
Scaling of fft in general is not standardised across various tools so keep that in mind.
for 2's complement inserting two leading zeros implies scaling by 4, nothing else.
Check the adc datasheet about their format. some adcs use offset binary in which case you just need to invert the sign bit to become 2's complement then you add two leading zeros.
Just correcting my last notes on fft testing.
injecting of one nonzero sample etc above applies to ifft.
For fft: inject a sine wave and you get one mirrored line (two samples or more depending on resolution issues). Injecting one nonzero sample implies impulse and so you get frequencies all over(not that halpful). Injecting constant samples without zeros implies dc so you get one line at zero frequency and so on.
--- Quote Start ---
--- Quote End ---
If I got this unsigned binary 100 (which is 4)
and I put 2 zero's in front 00100, the number is still 4 right? but it is now signed because the MSB is standard a 0. I know it is wrong when working with negative values, but keep in mind that the ADC only gives positive values.
Please correct me if i'm wrong.
--- Quote Start ---
--- Quote End ---
correct.
if ADC outputs positive only then it will have +dc.
Thanks for answering my (noobish) questions Kaz. I'm currently figuring out what to do with that exponent part. For now I have another question: This is what excel makes of my little formula : FFToutputframe * samplefrequency*FFTPOINTS=spectrum output of FFT.
Can you verify if this is correct? And, should I only use the first 256 results? And for last: I do not have 256 spectrums on the screen. Is it ok to, let say add the amplitudes of 390,625 and 481,25 and then divide it by two, to fit in a 300 to 500 hz range on the screen?
0 200000 512 0 1 200000 512 390,625 2 200000 512 781,25 3 200000 512 1171,875 4 200000 512 1562,5 5 200000 512 1953,125 6 200000 512 2343,75 7 200000 512 2734,375 8 200000 512 3125 9 200000 512 3515,625 10 200000 512 3906,25 11 200000 512 4296,875 12 200000 512 4687,5 13 200000 512 5078,125 14 200000 512 5468,75 15 200000 512 5859,375 16 200000 512 6250 17 200000 512 6640,625 18 200000 512 7031,25 19 200000 512 7421,875 20 200000 512 7812,5 21 200000 512 8203,125 22 200000 512 8593,75 23 200000 512 8984,375 24 200000 512 9375 25 200000 512 9765,625 26 200000 512 10156,25 27 200000 512 10546,875 28 200000 512 10937,5 29 200000 512 11328,125 30 200000 512 11718,75 31 200000 512 12109,375 32 200000 512 12500 33 200000 512 12890,625 34 200000 512 13281,25 35 200000 512 13671,875 36 200000 512 14062,5 37 200000 512 14453,125 38 200000 512 14843,75 39 200000 512 15234,375 40 200000 512 15625 41 200000 512 16015,625 42 200000 512 16406,25 43 200000 512 16796,875 44 200000 512 17187,5 45 200000 512 17578,125 46 200000 512 17968,75 47 200000 512 18359,375 48 200000 512 18750 49 200000 512 19140,625 50 200000 512 19531,25 51 200000 512 19921,875 52 200000 512 20312,5 53 200000 512 20703,125 54 200000 512 21093,75 55 200000 512 21484,375 56 200000 512 21875 57 200000 512 22265,625 58 200000 512 22656,25 59 200000 512 23046,875 60 200000 512 23437,5 61 200000 512 23828,125 62 200000 512 24218,75 63 200000 512 24609,375 64 200000 512 25000 65 200000 512 25390,625 66 200000 512 25781,25 67 200000 512 26171,875 68 200000 512 26562,5 69 200000 512 26953,125 70 200000 512 27343,75 71 200000 512 27734,375 72 200000 512 28125 73 200000 512 28515,625 74 200000 512 28906,25 75 200000 512 29296,875 76 200000 512 29687,5 77 200000 512 30078,125 78 200000 512 30468,75 79 200000 512 30859,375 80 200000 512 31250 81 200000 512 31640,625 82 200000 512 32031,25 83 200000 512 32421,875 84 200000 512 32812,5 85 200000 512 33203,125 86 200000 512 33593,75 87 200000 512 33984,375 88 200000 512 34375 89 200000 512 34765,625 90 200000 512 35156,25 91 200000 512 35546,875 92 200000 512 35937,5 93 200000 512 36328,125 94 200000 512 36718,75 95 200000 512 37109,375 96 200000 512 37500 97 200000 512 37890,625 98 200000 512 38281,25 99 200000 512 38671,875 100 200000 512 39062,5 101 200000 512 39453,125 102 200000 512 39843,75 103 200000 512 40234,375 104 200000 512 40625 105 200000 512 41015,625 106 200000 512 41406,25 107 200000 512 41796,875 108 200000 512 42187,5 109 200000 512 42578,125 110 200000 512 42968,75 111 200000 512 43359,375 112 200000 512 43750 113 200000 512 44140,625 114 200000 512 44531,25 115 200000 512 44921,875 116 200000 512 45312,5 117 200000 512 45703,125 118 200000 512 46093,75 119 200000 512 46484,375 120 200000 512 46875 121 200000 512 47265,625 122 200000 512 47656,25 123 200000 512 48046,875 124 200000 512 48437,5 125 200000 512 48828,125 126 200000 512 49218,75 127 200000 512 49609,375 128 200000 512 50000 129 200000 512 50390,625 130 200000 512 50781,25 131 200000 512 51171,875 132 200000 512 51562,5 133 200000 512 51953,125 134 200000 512 52343,75 135 200000 512 52734,375 136 200000 512 53125 137 200000 512 53515,625 138 200000 512 53906,25 139 200000 512 54296,875 140 200000 512 54687,5 141 200000 512 55078,125 142 200000 512 55468,75 143 200000 512 55859,375 144 200000 512 56250 145 200000 512 56640,625 146 200000 512 57031,25 147 200000 512 57421,875 148 200000 512 57812,5 149 200000 512 58203,125 150 200000 512 58593,75 151 200000 512 58984,375 152 200000 512 59375 153 200000 512 59765,625 154 200000 512 60156,25 155 200000 512 60546,875 156 200000 512 60937,5 157 200000 512 61328,125 158 200000 512 61718,75 159 200000 512 62109,375 160 200000 512 62500 161 200000 512 62890,625 162 200000 512 63281,25 163 200000 512 63671,875 164 200000 512 64062,5 165 200000 512 64453,125 166 200000 512 64843,75 167 200000 512 65234,375 168 200000 512 65625 169 200000 512 66015,625 170 200000 512 66406,25 171 200000 512 66796,875 172 200000 512 67187,5 173 200000 512 67578,125 174 200000 512 67968,75 175 200000 512 68359,375 176 200000 512 68750 177 200000 512 69140,625 178 200000 512 69531,25 179 200000 512 69921,875 180 200000 512 70312,5 181 200000 512 70703,125 182 200000 512 71093,75 183 200000 512 71484,375 184 200000 512 71875 185 200000 512 72265,625 186 200000 512 72656,25 187 200000 512 73046,875 188 200000 512 73437,5 189 200000 512 73828,125 190 200000 512 74218,75 191 200000 512 74609,375 192 200000 512 75000 193 200000 512 75390,625 194 200000 512 75781,25 195 200000 512 76171,875 196 200000 512 76562,5 197 200000 512 76953,125 198 200000 512 77343,75 199 200000 512 77734,375 200 200000 512 78125 201 200000 512 78515,625 202 200000 512 78906,25 203 200000 512 79296,875 204 200000 512 79687,5 205 200000 512 80078,125 206 200000 512 80468,75 207 200000 512 80859,375 208 200000 512 81250 209 200000 512 81640,625 210 200000 512 82031,25 211 200000 512 82421,875 212 200000 512 82812,5 213 200000 512 83203,125 214 200000 512 83593,75 215 200000 512 83984,375 216 200000 512 84375 217 200000 512 84765,625 218 200000 512 85156,25 219 200000 512 85546,875 220 200000 512 85937,5 221 200000 512 86328,125 222 200000 512 86718,75 223 200000 512 87109,375 224 200000 512 87500 225 200000 512 87890,625 226 200000 512 88281,25 227 200000 512 88671,875 228 200000 512 89062,5 229 200000 512 89453,125 230 200000 512 89843,75 231 200000 512 90234,375 232 200000 512 90625 233 200000 512 91015,625 234 200000 512 91406,25 235 200000 512 91796,875 236 200000 512 92187,5 237 200000 512 92578,125 238 200000 512 92968,75 239 200000 512 93359,375 240 200000 512 93750 241 200000 512 94140,625 242 200000 512 94531,25 243 200000 512 94921,875 244 200000 512 95312,5 245 200000 512 95703,125 246 200000 512 96093,75 247 200000 512 96484,375 248 200000 512 96875 249 200000 512 97265,625 250 200000 512 97656,25 251 200000 512 98046,875 252 200000 512 98437,5 253 200000 512 98828,125 254 200000 512 99218,75 255 200000 512 99609,375 256 200000 512 100000
second part:
257 200000 512 100390,625 258 200000 512 100781,25 259 200000 512 101171,875 260 200000 512 101562,5 261 200000 512 101953,125 262 200000 512 102343,75 263 200000 512 102734,375 264 200000 512 103125 265 200000 512 103515,625 266 200000 512 103906,25 267 200000 512 104296,875 268 200000 512 104687,5 269 200000 512 105078,125 270 200000 512 105468,75 271 200000 512 105859,375 272 200000 512 106250 273 200000 512 106640,625 274 200000 512 107031,25 275 200000 512 107421,875 276 200000 512 107812,5 277 200000 512 108203,125 278 200000 512 108593,75 279 200000 512 108984,375 280 200000 512 109375 281 200000 512 109765,625 282 200000 512 110156,25 283 200000 512 110546,875 284 200000 512 110937,5 285 200000 512 111328,125 286 200000 512 111718,75 287 200000 512 112109,375 288 200000 512 112500 289 200000 512 112890,625 290 200000 512 113281,25 291 200000 512 113671,875 292 200000 512 114062,5 293 200000 512 114453,125 294 200000 512 114843,75 295 200000 512 115234,375 296 200000 512 115625 297 200000 512 116015,625 298 200000 512 116406,25 299 200000 512 116796,875 300 200000 512 117187,5 301 200000 512 117578,125 302 200000 512 117968,75 303 200000 512 118359,375 304 200000 512 118750 305 200000 512 119140,625 306 200000 512 119531,25 307 200000 512 119921,875 308 200000 512 120312,5 309 200000 512 120703,125 310 200000 512 121093,75 311 200000 512 121484,375 312 200000 512 121875 313 200000 512 122265,625 314 200000 512 122656,25 315 200000 512 123046,875 316 200000 512 123437,5 317 200000 512 123828,125 318 200000 512 124218,75 319 200000 512 124609,375 320 200000 512 125000 321 200000 512 125390,625 322 200000 512 125781,25 323 200000 512 126171,875 324 200000 512 126562,5 325 200000 512 126953,125 326 200000 512 127343,75 327 200000 512 127734,375 328 200000 512 128125 329 200000 512 128515,625 330 200000 512 128906,25 331 200000 512 129296,875 332 200000 512 129687,5 333 200000 512 130078,125 334 200000 512 130468,75 335 200000 512 130859,375 336 200000 512 131250 337 200000 512 131640,625 338 200000 512 132031,25 339 200000 512 132421,875 340 200000 512 132812,5 341 200000 512 133203,125 342 200000 512 133593,75 343 200000 512 133984,375 344 200000 512 134375 345 200000 512 134765,625 346 200000 512 135156,25 347 200000 512 135546,875 348 200000 512 135937,5 349 200000 512 136328,125 350 200000 512 136718,75 351 200000 512 137109,375 352 200000 512 137500 353 200000 512 137890,625 354 200000 512 138281,25 355 200000 512 138671,875 356 200000 512 139062,5 357 200000 512 139453,125 358 200000 512 139843,75 359 200000 512 140234,375 360 200000 512 140625 361 200000 512 141015,625 362 200000 512 141406,25 363 200000 512 141796,875 364 200000 512 142187,5 365 200000 512 142578,125 366 200000 512 142968,75 367 200000 512 143359,375 368 200000 512 143750 369 200000 512 144140,625 370 200000 512 144531,25 371 200000 512 144921,875 372 200000 512 145312,5 373 200000 512 145703,125 374 200000 512 146093,75 375 200000 512 146484,375 376 200000 512 146875 377 200000 512 147265,625 378 200000 512 147656,25 379 200000 512 148046,875 380 200000 512 148437,5 381 200000 512 148828,125 382 200000 512 149218,75 383 200000 512 149609,375 384 200000 512 150000 385 200000 512 150390,625 386 200000 512 150781,25 387 200000 512 151171,875 388 200000 512 151562,5 389 200000 512 151953,125 390 200000 512 152343,75 391 200000 512 152734,375 392 200000 512 153125 393 200000 512 153515,625 394 200000 512 153906,25 395 200000 512 154296,875 396 200000 512 154687,5 397 200000 512 155078,125 398 200000 512 155468,75 399 200000 512 155859,375 400 200000 512 156250 401 200000 512 156640,625 402 200000 512 157031,25 403 200000 512 157421,875 404 200000 512 157812,5 405 200000 512 158203,125 406 200000 512 158593,75 407 200000 512 158984,375 408 200000 512 159375 409 200000 512 159765,625 410 200000 512 160156,25 411 200000 512 160546,875 412 200000 512 160937,5 413 200000 512 161328,125 414 200000 512 161718,75 415 200000 512 162109,375 416 200000 512 162500 417 200000 512 162890,625 418 200000 512 163281,25 419 200000 512 163671,875 420 200000 512 164062,5 421 200000 512 164453,125 422 200000 512 164843,75 423 200000 512 165234,375 424 200000 512 165625 425 200000 512 166015,625 426 200000 512 166406,25 427 200000 512 166796,875 428 200000 512 167187,5 429 200000 512 167578,125 430 200000 512 167968,75 431 200000 512 168359,375 432 200000 512 168750 433 200000 512 169140,625 434 200000 512 169531,25 435 200000 512 169921,875 436 200000 512 170312,5 437 200000 512 170703,125 438 200000 512 171093,75 439 200000 512 171484,375 440 200000 512 171875 441 200000 512 172265,625 442 200000 512 172656,25 443 200000 512 173046,875 444 200000 512 173437,5 445 200000 512 173828,125 446 200000 512 174218,75 447 200000 512 174609,375 448 200000 512 175000 449 200000 512 175390,625 450 200000 512 175781,25 451 200000 512 176171,875 452 200000 512 176562,5 453 200000 512 176953,125 454 200000 512 177343,75 455 200000 512 177734,375 456 200000 512 178125 457 200000 512 178515,625 458 200000 512 178906,25 459 200000 512 179296,875 460 200000 512 179687,5 461 200000 512 180078,125 462 200000 512 180468,75 463 200000 512 180859,375 464 200000 512 181250 465 200000 512 181640,625 466 200000 512 182031,25 467 200000 512 182421,875 468 200000 512 182812,5 469 200000 512 183203,125 470 200000 512 183593,75 471 200000 512 183984,375 472 200000 512 184375 473 200000 512 184765,625 474 200000 512 185156,25 475 200000 512 185546,875 476 200000 512 185937,5 477 200000 512 186328,125 478 200000 512 186718,75 479 200000 512 187109,375 480 200000 512 187500 481 200000 512 187890,625 482 200000 512 188281,25 483 200000 512 188671,875 484 200000 512 189062,5 485 200000 512 189453,125 486 200000 512 189843,75 487 200000 512 190234,375 488 200000 512 190625 489 200000 512 191015,625 490 200000 512 191406,25 491 200000 512 191796,875 492 200000 512 192187,5 493 200000 512 192578,125 494 200000 512 192968,75 495 200000 512 193359,375 496 200000 512 193750 497 200000 512 194140,625 498 200000 512 194531,25 499 200000 512 194921,875 500 200000 512 195312,5 501 200000 512 195703,125 502 200000 512 196093,75 503 200000 512 196484,375 504 200000 512 196875 505 200000 512 197265,625 506 200000 512 197656,25 507 200000 512 198046,875 508 200000 512 198437,5 509 200000 512 198828,125 510 200000 512 199218,75 511 200000 512 199609,375 512 200000 512 200000
I better explain fft output to you than answer your figures which are not clear to me:
N points fft output means N bins covering frequencies of +/- sampling frequency/2, (and usually indexed as 0 ~ N-1)
approximately:
bins 0~N/2 represent frequency range 0 ~ Fs/2 (Fs = sampling frequency sample/sec)
bins N/2+1 ~ N-1 represent frequency range -Fs/2 ~ 0
thus dc is at start and end(wrap up)
If your signal is real only then both halves get equal (mirror)
thus frequency of spectrum at point n: f(n) = Fs * n/N in Hz and its amplitude or phase is the value of amplitude or phase at n
amplitude = sqrt(Re^2 + Im^2) as you know
If you require fft results then use some simple vector e.g. constant, tell me your resolution and I will get you the result.
Thanks for your explain Kaz. That makes things a bit clearer.
I looked closely to the way I feed the FFT and came to the conclusion that my system is correct. I also now know that the output of the FFT is a block floating point and not a signed integer like I treated it. I now have to find a way to do my Pythagoras thing with this floating point. There is a mecacore function wich converts floating points to integers, but this function only works with 32-bit floats. I got a 14 bit mantissa from the FFT and a 5 bit exponent. I will have to look for a solution here.
I now got this:
I only need to sign extend it, any tips to do that?
mux:PROCESS(fftexp,fftvalid) -- VARIABLE sel : STD_LOGIC_VECTOR(1 DOWNTO 0); BEGIN -- sel := s1 & s0; -- concatenate s1 and s0 if (fftvalid = '1') then CASE fftexp IS WHEN "110011" => full_range_real_out(26 downto 13) <= fftreal; --sll 13; -- -13 full_range_imag_out(26 downto 13) <= fftimag; --sll 13; -- -13 WHEN "110100" => full_range_real_out(25 downto 12) <= fftreal; --sll 12; -- -12 full_range_imag_out(25 downto 12) <= fftimag;-- sll 12; -- -12 WHEN "110101" => full_range_real_out(24 downto 11) <= fftreal;-- sll 11; -- -11 full_range_imag_out(24 downto 11) <= fftimag; --sll 11; -- -11 WHEN "110110" => full_range_real_out(23 downto 10) <= fftreal;-- sll 10; -- -10 full_range_imag_out(23 downto 10) <= fftimag;-- sll 10; -- -10 WHEN "110111" => full_range_real_out(22 downto 9) <= fftreal; --sll 9; -- -9 full_range_imag_out(22 downto 9) <= fftimag; -- sll 9; -- -9 WHEN "111000" => full_range_real_out(21 downto 8) <= fftreal; --sll 8; -- -8 full_range_imag_out(21 downto 8) <= fftimag; --sll 8; -- -8 WHEN "111001" => full_range_real_out(20 downto 7) <= fftreal; --sll 7; -- -7 full_range_imag_out (20 downto 7)<= fftimag; --sll 7; -- -7 WHEN "111010" => full_range_real_out(19 downto 6) <= fftreal; --sll 6; -- -6 full_range_imag_out (19 downto 6) <= fftimag; --sll 6; -- -6 WHEN "111011" => full_range_real_out(18 downto 5) <= fftreal; --sll 5; -- -5 full_range_imag_out(18 downto 5) <= fftimag; --sll 5; -- -5 WHEN "111100" => full_range_real_out(17 downto 4) <= fftreal; --sll 4 -- -4 full_range_imag_out(17 downto 4) <= fftimag; --sll 4; -- -4 WHEN "111101" => full_range_real_out(16 downto 3) <= fftreal; --sll 3; -- -3 full_range_imag_out (16 downto 3)<= fftimag; --sll 3; -- -3 WHEN OTHERS => END CASE; end if; END PROCESS mux;
to sign extend say 12 to 16 bits:
data2 <= std_logic_vector(resize(signed(data1),16));
another note: for testing you can test Real and imaginary outputs directly (no need for old Pythogoras)
The code is complete, could you please verify if this is correct?
mux:PROCESS(fftexp,fftvalid) -- VARIABLE sel : STD_LOGIC_VECTOR(1 DOWNTO 0); BEGIN -- sel := s1 & s0; -- concatenate s1 and s0 if (fftvalid = '1') then CASE fftexp IS WHEN "110011" => full_range_real_out(26 downto 13) <= fftreal ; --sll 13; -- -13 full_range_real_out(12 downto 0) <= (OTHERS => '0'); full_range_imag_out(26 downto 13) <= fftimag; --sll 13; -- -13 full_range_imag_out(12 downto 0) <= (OTHERS => '0'); --sll 13; -- -13 WHEN "110100" => full_range_real_out(26)<=fftreal(13); full_range_real_out(25 downto 12) <= fftreal; --sll 12; -- -12 full_range_real_out(11 downto 0) <= (OTHERS => '0'); full_range_imag_out(26)<=fftimag(13); full_range_imag_out(25 downto 12) <= fftimag;-- sll 12; -- -12 full_range_imag_out(11 downto 0) <= (OTHERS => '0'); WHEN "110101" => full_range_real_out(26 downto 25) <= fftreal(13) & fftreal(13); full_range_real_out(24 downto 11) <= fftreal;-- sll 11; -- -11 full_range_real_out(10 downto 0) <= (OTHERS => '0'); full_range_imag_out(26 downto 25) <=fftimag(13) & fftimag(13); full_range_imag_out(24 downto 11) <= fftimag; --sll 11; -- -11 full_range_imag_out(10 downto 0) <= (OTHERS => '0'); WHEN "110110" => full_range_real_out(26 downto 24) <= fftreal(13) & fftreal(13)& fftreal(13); full_range_real_out(23 downto 10) <= fftreal;-- sll 10; -- -10 full_range_real_out(9 downto 0) <= (OTHERS => '0'); full_range_imag_out(26 downto 24) <=fftimag(13) & fftimag(13)& fftimag(13); full_range_imag_out(23 downto 10) <= fftimag;-- sll 10; -- -10 full_range_imag_out(9 downto 0) <= (OTHERS => '0'); WHEN "110111" => full_range_real_out(26 downto 23) <= fftreal(13) & fftreal(13)& fftreal(13)& fftreal(13); full_range_real_out(22 downto 9) <= fftreal; --sll 9; -- -9 full_range_real_out(8 downto 0) <= (OTHERS => '0'); full_range_imag_out(26 downto 23) <=fftimag(13) & fftimag(13)& fftimag(13)& fftimag(13); full_range_imag_out(22 downto 9) <= fftimag; -- sll 9; -- -9 full_range_imag_out(8 downto 0) <= (OTHERS => '0'); WHEN "111000" => full_range_real_out(26 downto 22) <= fftreal(13) & fftreal(13)& fftreal(13)& fftreal(13)& fftreal(13); full_range_real_out(21 downto 8) <= fftreal; --sll 8; -- -8 full_range_real_out(7 downto 0) <= (OTHERS => '0'); full_range_imag_out(26 downto 22) <=fftimag(13) & fftimag(13)& fftimag(13)& fftimag(13)& fftimag(13); full_range_imag_out(21 downto 8) <= fftimag; --sll 8; -- -8 full_range_imag_out(7 downto 0) <= (OTHERS => '0'); WHEN "111001" => full_range_real_out(26 downto 21) <= fftreal(13) & fftreal(13)& fftreal(13)& fftreal(13)& fftreal(13)& fftreal(13); full_range_real_out(20 downto 7) <= fftreal; --sll 7; -- -7 full_range_real_out(6 downto 0) <= (OTHERS => '0'); full_range_imag_out(26 downto 21) <=fftimag(13) & fftimag(13)& fftimag(13)& fftimag(13)& fftimag(13)& fftimag(13); full_range_imag_out (20 downto 7)<= fftimag; --sll 7; -- -7 full_range_imag_out(6 downto 0) <= (OTHERS => '0'); WHEN "111010" => full_range_real_out(26 downto 20) <= fftreal(13) & fftreal(13)& fftreal(13)& fftreal(13)& fftreal(13)& fftreal(13)& fftreal(13); full_range_real_out(19 downto 6) <= fftreal; --sll 6; -- -6 full_range_real_out(5 downto 0) <= (OTHERS => '0'); full_range_imag_out(26 downto 20) <=fftimag(13) & fftimag(13)& fftimag(13)& fftimag(13)& fftimag(13)& fftimag(13)& fftimag(13); full_range_imag_out (19 downto 6) <= fftimag; --sll 6; -- -6 full_range_imag_out(5 downto 0) <= (OTHERS => '0'); WHEN "111011" => full_range_real_out(26 downto 19) <= fftreal(13) & fftreal(13)& fftreal(13)& fftreal(13)& fftreal(13)& fftreal(13)& fftreal(13)& fftreal(13); full_range_real_out(18 downto 5) <= fftreal; --sll 5; -- -5 full_range_real_out(4 downto 0) <= (OTHERS => '0'); full_range_imag_out(26 downto 19) <=fftimag(13) & fftimag(13)& fftimag(13)& fftimag(13)& fftimag(13)& fftimag(13)& fftimag(13)& fftimag(13); full_range_imag_out(18 downto 5) <= fftimag; --sll 5; -- -5 full_range_imag_out(4 downto 0) <= (OTHERS => '0'); WHEN "111100" => full_range_real_out(26 downto 18) <= fftreal(13) & fftreal(13)& fftreal(13)& fftreal(13)& fftreal(13)& fftreal(13)& fftreal(13)& fftreal(13)& fftreal(13); full_range_real_out(17 downto 4) <= fftreal; --sll 4 -- -4 full_range_real_out(3 downto 0) <= (OTHERS => '0'); full_range_imag_out(26 downto 18) <=fftimag(13) & fftimag(13)& fftimag(13)& fftimag(13)& fftimag(13)& fftimag(13)& fftimag(13)& fftimag(13)& fftimag(13); full_range_imag_out(17 downto 4) <= fftimag; --sll 4; -- -4 full_range_imag_out(3 downto 0) <= (OTHERS => '0'); WHEN "111101" => full_range_real_out(26 downto 17) <= fftreal(13) & fftreal(13)& fftreal(13)& fftreal(13)& fftreal(13)& fftreal(13)& fftreal(13)& fftreal(13)& fftreal(13)& fftreal(13); full_range_real_out(16 downto 3) <= fftreal; --sll 3; -- -3 full_range_real_out(2 downto 0) <= (OTHERS => '0'); full_range_imag_out(26 downto 17) <=fftimag(13) & fftimag(13)& fftimag(13)& fftimag(13)& fftimag(13)& fftimag(13)& fftimag(13)& fftimag(13)& fftimag(13)& fftimag(13); full_range_imag_out (16 downto 3)<= fftimag; --sll 3; -- -3 full_range_imag_out(3 downto 0) <= (OTHERS => '0'); WHEN OTHERS => END CASE; end if; END PROCESS mux;
--- Quote Start ---
--- Quote End ---
I did'nt see you're comment in time. I now have done it manually
So Kaz, now I got these 2 huge vectors with the FFT's scaled real and imaginary data in. Now I have to Pythagoras them, right? But as what kind of format do I have to look at them?
Is it now an signed integer?
--- Quote Start ---
--- Quote End ---
yes once you do the scaling the values are signed 2's complement as input.
The output practically should not be that wide and you will need to observe the exponent as to what range is practical for your case then do some trimming on bits to fit fewer bits. You don't need to square it up to amplitude, you might just check each of real and imaginary directly.
I just put the real vector on the leds of the DE-1 board en saw that when I put music in, the leds are getting a bit nervous. This is a good thing I think. However, if I put our old Greek in. Amplitudes are the same af they were before scaling but now just a larger number.
Mind you, the only way I can test this is putting the result on the LEDs of the board because I have no Opencore IP license to do it in Modelsim.
