17254 Discussions
How can I generate a SerialLite II IP?
RMees
We have a license for SerialLite II.
But the IP Catalog only has a SerialLite III IP.
When I build the design with the SerialLite III IP I get :
Info (115017): Design contains a time-limited core -- only a single, time-limited programming file can be generated
That would indicate that the SerialLite III IP is NOT covered by the SerialLite II license.
Which is fine.
How do I generate the Serial II IP?
Vicky1
Can You check the device support for Serial II IP?
Choose the supported device from the below attached table & then try,
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
RMees
How do I file a "Service Request"?
Vicky1
Please refer the below link,
https://www.intel.com/content/www/us/en/programmable/support/support-resources.html
Check the My Intel option from below screen shot.
Let me know if this link is not worked for you.
Best Regards
Vikas Jathar
