Hallo,
I'm using Quartus 20.2. In my design in the Platform Designer I would like to add the 'altera_merlin_slave_translator'. I can find it in the 'intel_fpga_pro/ip/altera/... but not in the IP Catalog.
So how can I add it to my design?
regards
Mike
There is no need to manually add this component into a system design. It is automatically added into the interconnect as needed when you generate the system. What are you trying to do?
#iwork4intel
Thank you,
I learnt that I have to use the Avalon_clock_crossing_bridge instead of the older 'slave_translator'.
I had to generate my own read_data_valid, but finally it works.
A hint in the documentation that the older 'merlin' based connectors are replace by the Avalon_clock_crossing_bridge would have help a lot.
Mike
