17267 Discussions
How do I configure multiple licenses in Quartus prime pro?
Loopback
For the project specific requirement, I need a license for "Nios v/m microcontroller for Intel FPGA IP". If I generate a standalone evaluation license for 90 days, I'm able to see this option in the QPP 24.2, when I go to license setup menu and provide the location to the license file.
But, with the same license, the above Nios v/m option is not available in the QPP 24.1.
And we want to preferably go with QPP 24.1.
Which means I need to opt for License: IP-NIOSVM from the Intel self-service licensing center.
Which gives me a Nios v/m license along with 90 days evaluation license. How do I make Quartus include and consider both the licenses?
sstrell
I think when you generate the new no-cost license in the SSLC, you can choose an existing computer, so it would add the Nios V licensing to your existing license to create a new license file.
Loopback
Do you mean that Nios V license along with 90 days Quartus evaluation license will be generated as a single file?
sstrell
I haven't done it myself but that's what it looks like when I go into the SSLC.
AR_A_Intel
Hello
Welcome to INTEL. We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
To further check, may we know whether the license issue has been resolved on your end, or if you're still encountering any problems?
AR_A_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
