17258 Discussions
How to Clear Waveforms in Quartus' Built-in ModelSim?
ErenYagar
Hello everyone,
I'm currently using Quartus with its built-in ModelSim for my FPGA design projects. I've come across a situation where I need to clear the existing waveforms in ModelSim, but I'm not sure how to do it apart from using the 'restart' signal. Is there a way to completely clear the waveforms and start fresh?
Any guidance or instructions on how to achieve this would be greatly appreciated. Thank you in advance for your assistance!
SyafieqS
In ModelSim, you can clear the existing waveforms and start fresh by using the "Clear Waveform" option. This will remove all waveforms from the waveform window, allowing you to start over.
  1. Open ModelSim from within Quartus, and make sure your simulation is running or paused.
  2. In the ModelSim main window, navigate to the "Wave" menu at the top.
  3. From the "Wave" menu, select "Clear Waveform." Alternatively, you can use the keyboard shortcut Ctrl + W (or Command + W on macOS) to clear the waveforms.
  4. All the waveforms in the waveform window will be removed, and you'll have a clean slate to add new signals and start fresh.
SyafieqS
Let me know if there is any update
SyafieqS
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
