hi all....im currently need to build a simple Mp3 player which able to player Mp3 files from the SD card using De2 board...i have successfully able to play Wav files from the DE2 Lab manual Demonstration (DE2_SD_Card_Audio)...but how if i wan to play MP3 files?any guidelines?thx!
連結已複製
5 回應
Sorry,
it is on http://www.nioswiki.com/nios2embeddedevaluationkit/mp3_player?gsa_pos=1&wt.oss_r=1&wt.oss=mp3%20player (hope this link works)The DE2 SDcard player only plays .WAV files, no MP3! So you should put some .wav files on the SD card and insert that in your DE2 board.
Read the manual by TerasIC! You must download BOTH your hardware to the DE2 board as well as the Nios2 software!!! Good Luck!
