17253 Discussions
How to check signal waveform.
I have this VHDL code within my architecture:
architecture first of butterfly8 is
signal butterfly8_r_Z1, butterfly8_r_Z2, butterfly8_r_Z3, butterfly8_r_Z4: std_logic_vector(31 downto 0);
I know that I can use Vector Waveform File to monitor my waveform of INPUT and OUTPUT pins. Would it be possible to monitor my signal, such as butterfly8_r_Z1 in the architecture? If so, how to do it? Thanks
There is usually more to a message than that. Can you expand it to get more info? What are the lines right around it? (For example, if it can't place the I/O it gives a message if it's a pure count, i.e. 700 pins needed, 650 available, or if it can't fit them all into I/O because of I/O standards, it lists some of the permutations it has tried).
I have set all of my input and output pins to VIRTUAL PINS. When I compile it, the following msg pop up :
Pls find the attachment
http://i27.tinypic.com/16m0ehw.jpg
remove any pin assignments you may have made in Pin Planner?
I have removed the pin assignments in PIN PLANNER. However, still having the same problem after compiled. Please find below picture:
http://i28.tinypic.com/yialu.jpg
The design uses 513 pins, so I'm guessing it didn't take. (I'm betting you assigned a bus with the virtual pins, but it needs to be assigned to each bit.) Look in the fitter report under input, output and bidir pins to see the usage.
Yes, I assigned a bus with the virtual pins!!!! Please find below Picture:
http://i31.tinypic.com/21bu4om.jpg
--- Quote Start ---
--- Quote End ---
i'm not sure about this, i am using virtual pins on a bus.
cwj: can you post a pic of your Assignment Editor window (with the Virtual pins)?
i don't think you need to fit the design (where you are running into pin problems) to do a functional simulation.
just run Analysis and Synthesis (or even just Analysis and Elaboration), then Generate Functional Simulation Netlist, then Start Simulation.
You mean I don't have to compile in full version. Just do Analysis and Sythesis...then Generate Functional Simulatio nNetlist and simulation?
for a functional simulation that is correct, you only need to run Analysis and Synthesis (actually only Analysis and Elaboration) rather than a full compilation.
i don't know why your Virtual Pins aren't taking though, that is strange.
I wrote a simple code as below and I assigned all my input and output pins to VIRTUAL PINS. However, I still have the same problems. Can't fit my pins when I performed a full compilation.
http://i25.tinypic.com/245ajpd.jpg http://i32.tinypic.com/2j0xhqw.jpg http://i32.tinypic.com/214scjd.jpg
http://i30.tinypic.com/2ivi5jl.jpg
I found an related topic over here:
http://www.alteraforum.com/forum/showthread.php?t=3912
ah, i see. there should probably be a solution to clarify that Virtual Pins are a feature of Incremental Compilation, which is not a part of Web Edition.
Virtual pins aren't part of incremental compilation, just not part of the webversion. I use virtual pins on designs without incremental compilation quite often. (But yes, if there's no message about the assignment being explicitly ignored, there should be.)
well unfortunately Virtual Pins don't appear on this comparison chart. is there a place that explicitly says they aren't included in Web Edition?
http://www.altera.com/literature/po/ss_quartussevswe.pdf
i'm sure it must be related to LogicLock or Incremental Compile.
That means not available in Web Edition?
If I perform 'start analysis and synthesis' then generate functional netlist. and perform simulation, it works fine!
well from your tests it appears that you cannot use Virtual Pins in Web Edition. i don't have that version installed so i can't confirm.
that's right, you'll save some time without running the full compilation/Fitter too. ;)
