17261 Discussions
How to compile RTL Module with OpenCL kernel ?
I'm looking for documentation about codesign RTL module with OpenCL kernel. How to transform my VHDL or verilog to XML ?
The Design example "OpenCL Library" (Advanced kernel code) show an example with RTL module and XML file ?
How to compile RTL module with Kernel Opencl, How to write XML file or how to trnasform xml from verilog ?
Do you have, please, any documentation about it ?
Thank you.
Documentation can be found on the OpenCL Programming Guide which details how to setup the XML and to create an RTL library to be used in OpenCL
https://www.altera.com/en_us/pdfs/literature/hb/opencl-sdk/aocl_programming_guide.pdf#_opentopic_toc_processing_d116e26845
Please refer to this example below,
https://www.altera.com/support/support-resources/design-examples/design-software/opencl/library-design-example.html
CloseCL
(This message was posted on behalf of Intel Corporation)
