17255 Discussions
How to create negative pin for LVDS in Cyclone II?
I want to test the ALTLVDS Megafunction on an Altera NIOS II Development Kit, which includes the CycloneII EP2C35F672C6N FPGA.
The intention is to check if I can replace an existing LVDS Transmitter Device on a PCB through an ALTLVDS Megafunction implemented in a Cyclone II FPGA. The FPGA is already on the PCB and after a redesign I could use some of the remaining LEs to implement the LVDS interface to drive a LCD Display. The LVDS Transmitter has 3 channels and a clock channel.
The deserialization factor is 7.
The test set-up is the following:
Intel XScale module with parallel output ports for the Display -> parallel cable to prototyping pins of the NIOS II Development Kit -> LVDS cable from the prototyping pins of the NIOS II Development Kit -> LVDS Display from NEC (640X480, 10,2")
The first problem that came up is, that in the Quartus Pin Planner I can´t create more than one or two differential pairs.
I´ve got 4 Pins of which i wanted to change the I/O Standard to LVDS.
As a result I should get the following output pins:
(In my example)
tx_out[2] and tx_out[2](n)
tx_out[1] and tx_out[1](n)
tx_out[0] and tx_out[0](n)
tx_outclock and tx_outclock(n)
Instead of this I get the following Differential Pairs:
tx_out[2] and tx_outclock
tx_out[1] and tx_out[0]
tx_out[0] and tx_out[1]
tx_outclock and tx_out[2]
Does anyone have any idea why the pin planner doesn´t creates a positive and a negative pin for each output channel after changing the I/O Standard to LVDS?
I´ve already been searching in various Altera Application Notes, Manuals and Handbooks, but I haven´t found anything helpful till now.
If anyone has a good tutorial on how to create a LVDS Display Interface in a Cyclone II FPGA it would be helpful too.
In the SERDES Transmitter/Receiver (ALTLVDS) Megafunction User Guide I didn´t found the answers to my questions.
Thanks for any ideas!
Greetings
Stefan
You don't have to assign the negative pin, it's assigned by the fitter automaticly.
I talked to an FAE who is a former employee of Altera and he told me, that my problem is a bug in Quartus 8.0 (SP1). To solve the problem I have to delete the db directory of my projekt and change the pin-assignment in the QSF File by myself.
@FvM: Thanks for your efforts!
Yeah, I noticed the same thing in Cyclone III. Quartus II does not create a differential pin but instead uses one of my pre-existing pins.
Strange. Seems like a large bug.
Thanks for the tip.
