17241 Discussions
How to disable a specific warning
OHarb1
I get megabytes of this warning.
What does it mean?
Can I disable it?
Warning (14320): Synthesized away node "top|fiddlybob|memory_rtl_1|auto_generated|q_b[4078]" File: /workspace/[deleted]/tmp-clearbox/top/975/altsyncram_v8j1.tdf Line: 114222
KennyTan_Altera
There seems to be noway to do it without GUI.
We do have message suppression manager . It is a form of *.sff that recognized by the quartus. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qts_qii52012.pdf but it GUI to handle the import and export.
looking into quartus_sh --qhelp -> report, it seems does not have this feature as well.
I will file an enhancement feature to our developer.
KennyTan_Altera
This means that this node is not connecting to anythings. you will have to check the connection in your design.
You can suppress message by right click on the messages -> suppress
OHarb1
  1. The warning is in code generated by Quartus: "altsyncram_v8j1.tdf". I can't connect the dots from what I did to getting this warning.
  2. I'm not using the user-interface, this is from a build server. I would like to suppress the files from the build log. Is there an option or tcl command to stop this warning from appearing during P&R?
KennyTan_Altera
OHarb1
Do you know what the option is called?
There are 41 references when I search for "warning", but none of them are about how to disable warnings.
KennyTan_Altera
look for the keyword of suppress
OHarb1
All I found was this option, it's not precise enough to suppress individual messages:
-suppress_messages
Specifies whether or not to suppress simulator specific information and warning messages issued during compilation. This option does not apply to tool specific error messages. Messages that are suppressed do not appear in a log file, if one was specified. If this option is not specified, then no messages are suppressed.
KennyTan_Altera
OHarb1
