17241 Discussions
I can't install devices arria10 (all part). Why?
Длаза
I did install quartus prime 18.0SE. Load devices "Arria10". When I launch Device Installer, in the “select components” window, after clicking next, a message appears: you didn't select any component for install. What should I do?
sstrell
Did you download the 3 device installation files (.qdz) needed?
https://fpgasoftware.intel.com/18.0/?edition=standard&platform=windows
#iwork4intel
Длаза
yes of course
sstrell
So it doesn't work even after pointing the device installer to the location of the .qdz files? Weird. I'd try downloading them again, double-checking to make sure they are the correct version of the files for the version of Quartus you've installed.
#iwork4intel
Длаза
I repeated downloading again and got the same result.
sstrell
If they’re grayed out like that, it means the device is already installed. Are you saying that when you create a new project or try to select an A10 device for an existing project that Quartus tells you the device is not installed? If so, I’d just uninstall Quartus and start over.
#iwork4intel
RichardTanSY_Altera
Hi, it seems to me that the Arria 10 device has been installed. Do you see any further issues after Quartus re-installation?
Длаза
Thank you. I reinstalled Quartus and components. It work.
RichardTanSY_Altera
I'm glad that the issue has been solved. I will proceed to close this case.
p.s. Don’t forget to Reply, and Select the Best Solution. :)
