17249 ディスカッション
I can't install devices arria10 (all part). Why?
Длаза
初心者
2,759件の閲覧回数
I did install quartus prime 18.0SE. Load devices "Arria10". When I launch Device Installer, in the “select components” window, after clicking next, a message appears: you didn't select any component for install. What should I do?
0 件の賞賛
8 返答(返信)
sstrell
名誉コントリビューター III
2,647件の閲覧回数
Did you download the 3 device installation files (.qdz) needed?
https://fpgasoftware.intel.com/18.0/?edition=standard&platform=windows
#iwork4intel
Длаза
初心者
2,647件の閲覧回数
yes of course
sstrell
名誉コントリビューター III
2,647件の閲覧回数
So it doesn't work even after pointing the device installer to the location of the .qdz files? Weird. I'd try downloading them again, double-checking to make sure they are the correct version of the files for the version of Quartus you've installed.
#iwork4intel
Длаза
初心者
2,647件の閲覧回数
I repeated downloading again and got the same result.
sstrell
名誉コントリビューター III
2,647件の閲覧回数
If they’re grayed out like that, it means the device is already installed. Are you saying that when you create a new project or try to select an A10 device for an existing project that Quartus tells you the device is not installed? If so, I’d just uninstall Quartus and start over.
#iwork4intel
RichardTanSY_Altera
モデレーター
2,647件の閲覧回数
Hi, it seems to me that the Arria 10 device has been installed. Do you see any further issues after Quartus re-installation?
Длаза
初心者
2,647件の閲覧回数
Thank you. I reinstalled Quartus and components. It work.
RichardTanSY_Altera
モデレーター
2,647件の閲覧回数
I'm glad that the issue has been solved. I will proceed to close this case.
p.s. Don’t forget to Reply, and Select the Best Solution. :)
返信
