17241 Discussions
How to get the equation (expression) from the synthesis tool?
LChow3
Refer Verilog code attached. After compilation, how can I get the equation (expression) for Y and z from the synthesis tool?
sstrell
Are you referring to the logic expression? Check the RTL Viewer under the Tools menu. You can look at logic blocks in that tool based on your RTL code and see the logic implementation.
#iwork4intel
