So from a fresh install of Ubuntu:
11.1sp1_216_quartus_free_linux.sh chmod +x 11.1sp1_216_quartus_free_linux.sh ./11.1sp1_216_quartus_free_linux.sh ./11.1sp1_216_quartus_free_linux.sh Creating directory 11.1sp1_216_quartus_free_linux Verifying archive integrity... All good. Uncompressing Quartus II Web Edition (Free).......................................................................................................................................................................................................................................................................................................................................................................................................Extraction failed. So I try to change couple of things that didn't help? sudo dpkg-reconfigure dash <no> to set bash as default. ls -al /bin/sh lrwxrwxrwx 1 root root 4 2012-01-25 08:41 /bin/sh -> bash sudo apt-get install ia32-libs csh any ideas? # ######################################################## # UPDATE: [SOLVED] # ######################################################## sudo bash ./11.1sp1_216_quartus_free_linux.sh Add the following lines to the /etc/udev/rules.d/51-usbblaster.rules file. # USB-Blaster BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001", MODE="0666" BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6002", MODE="0666" BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6003", MODE="0666" sudo apt-get install libxerces-c28 sudo apt-get install lib32icu44 cd altera/11.1sp1/quartus/ sudo cp /usr/lib/libxerces-c.so.28.0 linux64/libaxerces-c.so.26 sudo cp /usr/lib/libicudata.so.44 linux64/libicudata.so.34 sudo cp /usr/lib/libicuuc.so.44.2 linux64/libicuuc.so.33 sudo cp /usr/lib/libicuuc.so.44 ../linux64/libicuuc.so.34 sudo locale-gen en_US sudo apt-get install gtk2-engines-pixbuf链接已复制
23 回复数
You probably have a corrupted archive.
Make sure the MD5sum matches what's on the website for the downloaded file. md5sum should be installed already, if not it will tell you what package you need when you try to use it. Pete@anakha (http://www.alteraforum.com/forum/member.php?u=2471)
My md5sum was ok ;) sudo bash ./11.1sp1_216_quartus_free_linux.sh start the installation If the script is using specific feature of bash that are not supported in sh. so I replace in the file# !/bin/sh for # !/bin/bash and it solve the problem! So Altera should replace sh for bash in there script! Where is there bug report website to tell them? SUMMARIZED: sudo dpkg-reconfigure dash <no> sudo apt-get install ia32-libs sudo bash ./11.1sp1_216_quartus_free_linux.sh KAhello all!!!
someone can make usbblaster run on ubuntu 11.10???? i did 1 add on /etc/rc.localmount --bind /dev/bus /proc/bus
ln -s /sys/kernel/debug/usb/devices /proc/bus/usb/devices
2 add on /etc/udev/rules.d/51-usbblaster.rules SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001", MODE="0666", NAME="bus/usb/$env{BUSNUM}/$env{DEVNUM}", RUN+="/bin/chmod 0666 %c"
and when i did lsusb i see Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 002: ID 413c:3012 Dell Computer Corp. Optical Wheel Mouse
Bus 005 Device 003: ID 413c:2106 Dell Computer Corp. Dell QuietKey Keyboard
Bus 007 Device 004: ID 09fb:6001 Altera -> here
but when i do jtagconfig No JTAG hardware available
any ideia??? someone can help me ??? thanks Franz Wagner
Franz,in your post, you said you did:
2 add on /etc/udev/rules.d/51-usbblaster.rulesSUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001", MODE="0666", NAME="bus/usb/$env{BUSNUM}/$env{DEVNUM}", RUN+="/bin/chmod 0666 %c"
I want to know, if the version is quartus 8.0, should I change anything of the above content?
Hi, Franz
Thank's for your reply. I just succeeded install quartus II on Ubuntu11.10. But there are still some problems. When I compile the hello_word project, I had the message: **** Build of configuration Debug for project hello_world_0 **** make -s all includes Error: no processor component available. SOPC_BUILDER_PATH may be incorrectly set in your environment. make[1]: *** [proc_check] Error 1 make: *** [system_project] Error 2 Build completed in 11.841 seconds--- Quote Start --- hi, good afternoon yes ......actually i think did it works............which op system d u use? cheers Franz Wagner --- Quote End --- It did works. My system is Ubuntu 11.10.
ok ....
Hi, Franz
make: *** Error 1
make: *** Error 2
this happens because you dont have a nios2 processor in your design...... you need to add a processor, ram memory, jtag uart in sopc builder or open a nios2 example for your board cheers Franz Wagner
--- Quote Start --- hello all!!! someone can make usbblaster run on ubuntu 11.10???? i did 1 add on /etc/rc.local
--- Quote End --- This is explain alot on google and also on http://www.altera.com/download/drivers/dri-usb_b-lnx.html They should add a INSTALL or README file that explain that it will help ;) --- Quote Start --- but when i do jtagconfig No JTAG hardware available
any ideia??? someone can help me ??? thanks Franz Wagner --- Quote End --- Still having this issue: When I open the programmer I have this error on my console : /home/kapare/altera/11.1sp1/quartus/linux64/jtagd: error while loading shared libraries: libaxerces-c.so.26: wrong ELF class: ELFCLASS32 So this post solve my problem http://www.alteraforum.com/forum/showthread.php?t=33163 sudo apt-get install libxerces-c28 sudo cp /usr/lib/libxerces-c.so.28.0 linux64/libaxerces-c.so.26 sudo cp /usr/lib/libicudata.so.44 linux64/libicudata.so.34 sudo cp /usr/lib/libicuuc.so.44.2 linux64/libicuuc.so.33 sudo apt-get install lib32icu44 sudo cp /usr/lib/libicudata.so.44 ../linux64/libicudata.so.34 sudo cp /usr/lib/libicuuc.so.44 ../linux64/libicuuc.so.34 Then finally I was able to select USB-Blaster [1-1] But since I'm on a virtual machine on Mac the result of flashing is stil FAILED :( I heard that it was possible from a VM with windows??? will try it...
--- Quote Start --- But since I'm on a virtual machine on Mac the result of flashing is stil FAILED :( I heard that it was possible from a VM with windows??? will try it... --- Quote End --- I have VirtualBox running under Linux (Centos 6.2) and Windows XP hosts, and they allow the VM to capture the USB-Blaster interface (I've used Ubuntu, Centos, and Windows XP clients in the VM). Windows 7 will not. Cheers, Dave
--- Quote Start --- I have VirtualBox running under Linux (Centos 6.2) and Windows XP hosts, and they allow the VM to capture the USB-Blaster interface (I've used Ubuntu, Centos, and Windows XP clients in the VM). Windows 7 will not. Cheers, Dave --- Quote End --- Thx Dave, I have Mac OS 10.7 with VMWare Version 4.1.1 (536016) running Windows 7 64bits with Quartus sp2. I'm able to flash from my Windows 7 Machine :)) NOTE: I only check Program/Configure in the programmer otherwise if I check Verify it fail. So wait let me try on Ubuntu without the Verify option!!! RESULT: IT'S WORKING :p So my problem was the verify option removing this solve my problem. NOTE: I did test all the options only the Verify + Program/Configure. Kevyn-Alexandre
Hi Franz,
I got exact problem you met. However, even I try your solution, but I still can not make usb-blaster working on Ubuntu 12.04 64bit. Do you have any idea what is going on? --- Quote Start --- hello all!!! someone can make usbblaster run on ubuntu 11.10???? i did 1 add on /etc/rc.localmount --bind /dev/bus /proc/bus
Attached is my UDEV rules for Ubuntu 12.04. I know I had to modify them due to a change in UDEV system from 10.04 to 12.04, I've also added more variations, due to different dev kit versions of the USB blaster.
Let me know if these work for you. The number in the name: 53 vs 51 is just an ordering item, you can rename it as you wish. Remove the .txt extension. and copy into /etc/udev/rules.d Let me know if this helps. PeteHere what I do since 12.04. Usb-blaster is not always working properly in a VM!
1- sudo apt-get install ia32-libs-multiarch 2- tar xzvf 12.0sp1_232_modelsim_ase_linux.tar.gz 3- sudo bash ./setup I don't recall if I needed to start quartus as root (sudo) to have access USB-Blaster but I don't think so. We only use quartus for compilation on our build server and program it with Windows or our own devices. Hope it can help, -KA
