17255 Discussions
How to instantiate a float point IP in OpenCL-HDL hybrid flow?
I am putting a verilog module into OpenCL, and in the verilog, a float point ip is used.
Previously in pure HDL flow, I use .ip file with no problem. but now in OpenCL flow, seems .ip file is not supported. Then I am having problem instantiate this module.
I am using arria 10, and the ip is arria 10 naitive floating point adder with 3 stage pipeline.
What should I do? Please help.
I find some float point modules in hld/ip directory. These modules can be instantiated without problem. However, this didn't solve my problem, because I customized 3 stage float point adder using IP Parameter Editor. But in the hld/ip directory, there is no exact type.
Still expecting the answer. Can this be done by setting some parameters for twentynm_fp_mac?
--- Quote Start ---
--- Quote End ---
