17254 Discussions
How to sign-extend in Quartus ??
Hi
Guys, i need ur help in Quartus(altera software for designing)...
i want to know how to sign extend bit in quartus??
cause i have function that compare between 2 inputes(16bit) and if its less it will give(1) else(zero)... and then it will go the Mux
so, i need to sign extend it from 1 bit to 16 bit... how??? what is the function(name of it) that do this operations???
thanks alot...
How are you doing your design: schematic, VHDL, verilog?
Why do you need to extend one bit to sixteen bits? From what you've described, your vector is either all ones or all zeroes.
