Is there a settings dialog somewhere in the eclipse IDE (using quartus13.0sp1) that will show me where/which BSP that the eclipse project is pointing to/using? I have code that needs to run on 2 separate platforms and I would like to be able to change BSPs w/o a lot of copy/paste of code around.
Quartus13.0sp1/Eclipse Indigo Service Release 2 20120216-1857連結已複製
2 回應
First one location you need to change: right click on project -> Properties -> Nios II Application Properties -> BSP project location
and the second one: right click on project -> Properties -> Project References
