17267 Discussions
How to use MACRO on altera modelsim
SHung4
I add a MACRO on Setting-compiler setting-Verilog HDL input, and it works.
But when I run RTL sim by altera modelsim, it seem that it don't use the MACRO. What is the right way to use MACRO on altera modelsim, thanks.
AnandRaj_S_Intel
In the Transcript window
->do <file name >.do
Will run the macro.
For more information refer below links
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_gs_msa_qii.pdf
http://home.eng.iastate.edu/~zzhang/courses/cpre581-f05/resources/modelsim.pdf
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
SHung4
I write the code in verilog file like this:
`ifdef FPGA
`endif​
And I can use Setting-compiler setting-Verilog HDL input to add a macro FPGA when synthesis.
But I find that it don't work when run RTL-simulation.
AnandRaj_S_Intel
+define+<macro_name>[=<macro_text>]
I have used simple example
########################CODE##########################
module and_op (a, b, c);
output a;
input b, c;
`ifdef behavioral
wire a = b & c;
`else
or a1 (a,b,c);
`endif
endmodule
##########################CODE####################
​vlog +define+behavioral -work work and_op.v
Anand Raj Shankar
SHung4
Is there any method to add some setting on Quartus, so that I can push "Tools/Run Simulation/RTL Simulation" to run simulation?
AnandRaj_S_Intel
Yes,
We can have simple .do script to set the simulation environment(macro enabled).
To launch simulation from Quartus.
Assignments->settings->EDA tool Settings->simulation->tool name Modelsim-Altera ->select the option "script to compile test bench" -> input the .do with the macro which you want enable.
To run the simulation from Quartus
Tools->Run Simulation Tools->RTL Simulations.
Refer image for more information.
I have used about code with simple .do file .
------------.do---------------
vlog +define+behavioral -work work C:/......./macro/and_op.v
Which will launch Modelsim and run simulation for the enabled macro.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)macroQuartusModelsim.png
