17258 Discussions
How to write tcl command in sdc file for generated clock inside a component?
I have a system design, inside this top design, there are several components. E.g. :One of component name is "A", and its instance is "a". If there is a generated clock is clk_160ns (wire) , which is generated through a counter, the counter is drive through a 40ns clock (clk).
Then I try to write command in .sdc file:
create_generated_clock -name clk_160ns -source [get_ports {clk}] -divide_by 4 [get_nets a|clk_160ns]
But after I use TimeQuest, it still can not find this clock, anybody can help me to edit the tcl command?
Thanks very much.
You can use GUI to create the clock,then copy the command to the sdc file.
--- Quote Start ---
--- Quote End ---
Yes, I try to use GUI “Insert Constraint”, but I can't find that wire I want in GUI. Any other approach?
Thanks very much.
Your problem is that you are trying to assign the clock to a net, and the clock is traversing through a register, which is a timing node. You cannot traverse through a timing node to do this. If you make your target of your generated clock the register bit that is driving that net, it will work as you expect.
create_generated_clock -name {clk_160ns} -source [get_ports {clk}] -divide_by 4 [get_registers {a[2]}]
(This assumes that bit 2 of your register "a" is what is driving the divide by 4 on the input clock).
--- Quote Start ---
--- Quote End ---
Thanks very much, jimbo. I think I got what you mean. If still take my design as the example, in my module instance "a", I have a 2bit counter instance "counter_a" is drived by 40 ns clock, so the the 2nd bit output of "counter_a" is the clock "clk_160ns". I should write the command as:
create_generated_clock -name {clk_160ns} -source [get_ports {clk}] -divide_by 4 [get_registers {a|counter_a[2]}]
Is that right?
Yes, that should work. I assume you already have a create_clock constraint for the input clock on port {clk}, right?
--- Quote Start ---
--- Quote End ---
Yes, I do. I will try this later, if there is still problem, I will post here again. Thanks so much.
