I have attached 2 files. H_777)IC33_Altera_03.JAM passes using 3rd party corelis tool. The other file I recently regenerated with Quartus 19.2 using the same .JIC and bsd files. I suspect somethings not right with Quartus algorithm. I would rather not have to go back and download Quartus 11.0.
Third file is a screenshot of the failure. It doesnt recognize the eps128?
Hi Mark,
I am having issue in opening the file that you attached. Exit Code 6 indicates that the Device ID is not recognized, you might need to add that inside the JAM to fix the exit code.
YL
Which file are having an issue with opening? I used 7zip to to archive the files. There is no password.
OOps I forgot to mention the eps128 is in the .Jam file that's whats odd.
Hi Mark,
I am still not able to get the file downloaded and opened. May i know have you refer to the other command while adding the EPS128?
Thank You.
