17261 Discussions
I would ask for help with error message when .qar file is generated.
JKoty
Hi
I would ask for help with issue.
I have Quartus Pro edition 18.1 build 222.
When I run command:
project_archive c10_pcie.qar -include_libraries
from .tcl file system return me error message:
Info: ----------------------------------------------------------
Info: Generated archive 'c10_pcie.qar'
Info: Generated report 'c10_pcie.archive.rpt'
Error (125085): The Quartus Prime Settings File changed outside of the Quartus Prime software and contains errors. Rewriting the Quartus Prime Settings File with the current state of assignments in the Quartus Prime software.
Error (293007): Current module quartus_sh ended unexpectedly. Verify that you have sufficient memory available to compile your design. You can view disk space and physical RAM requirements on the System and Software Requirements page of the Intel FPGA website (http://dl.altera.com/requirements/).
Sript was run it on notebook with memory 16GB but also on server cluster with 32GB and enough CPU resources.
Do you have tips how to solve his issue?
SyafieqS
Hi Jan,
The error showed due to not matching the system requirement. Make sure you match all the specifications e.g OS, RAM depending on targeting device. Refer to link below for details.
https://www.intel.com/content/dam/altera-www/global/en_US/others/download/os-support/readme-qp181.txt
https://fpgasoftware.intel.com/requirements/18.1/
JKoty
I double check that we are matching all system requirements. We now are run on Centos 7 OS, which is binary compatible with Read Head 7. We are running on this OS all others build with .qar part of code (For Quartus standart Edittion) and all is right. Do you know about any reasons why Quartus Pro editions shouldn't run on this OS?
Best Regards
Jan
JKoty
I spoke with IT department in our company and we are sure, that we are fulfill all system requirements for Quartus 18.1 Pro with Cyclone 10 device. It is error which is for our product showstopper.
J.
SyafieqS
Hi Jan,
Could you provide the .qar file and steps how you you were getting the error for me to replicate it.
​​​​​​​Regards
JKoty
Hi, I am preparing for you dummy project where should be reproducible our issue. How I should share it with you? It is not good idea to share it on public forums. Best regards Jan
SyafieqS
Hi Jan,
You can use email feature there..
JKoty
Hi, I removed almost all from the our project and there is only part of our framework and design only with PCIe HARD IP. Inside archive is build project to save some time from your side. To reproduce our issue you need have all tools in Paths (We are now using Quartus Prime Version 18.1.0 Build 222 09/21/2018 SJ Pro Edition ) and run only target "Archive project" in impl/c10_pcie/impl.tcl. Now are UN-Commented ALL targets for case you would like to see all steps. We are run impl.tcl by type "make compilation"
I believe that you will be able to reproduce it.
Best regards
Jan
JKoty
it is looks like we found solution, is not tested on server yet but on PC is looks good. We updated Quartus 18.1.0 to 18.1.2.
Jan
CosmoKramer
Hi, I am having same error. Could you please share the solution that fixed the error.
thank you
