I2C Max10
gomezramones
Hi, I am trying to communicate my FPGA to ADXL345 using I2C protocol. There is an example or guide to start the communication in a Max10? Also I have other question, I created my Qsys file to use Avalon I2C (Master) Intel FPGA IP and I notice there is CSR register which has ADD[3..0] / Write / Read / writeaddres[31..0] / readaddress[31..0]. So my question is when do I use this CSR register? Does the slave unit require CSR pin as well to able to use this control register?
Mengzhe
I found no specific example for I2C connection of MAX10 with peripheral device offered​, but you can search for related info from FPGA Design Store | Intel.
And Avalon interface is for inner communication for different part in FPGA, not for peripheral connection.
BR,
Mengzhe
gomezramones
Thank you for the response. Do you have any guide about how to use that avalon interface? Because I have been reading Embedded Peripherals IP User Guide but it doesn't explain deeply the I2C CSR interface.
Mengzhe
Please refer to this design and let me know if you have any questions.
MAX 10 - I2C Remote System Update Example (intel.com)
In this example, we use I2C to communication with external device for RSU.
