17241 Discussions
Impossible to generate a preloader with cyclone V
JBeau2
I have a problem to generate the preloader with the DE0_Nano_Soc.
The configuration is the following:
Quartus Lite 18.01 and DS5 standard edition V18.01 on Windows 10,
I created a sample project following the documentation: SoC-FPGA Design Guide DE0-Nano-SoC Edition / LAP – IC – EPFL / Version 1.32 of Sahand Kashani-Akhavan & René Beuchat.
I can compile the quartus project without error but with a lot of warning: (826).
Then I ran BSP-Editor without problem.
Then I change the directory and launch the command “make”:
cd C:\intelFPGA\18.1\DE0_Nano_Soc_demo\hw\quartus\software\spl_bsp
make
I had to modify the path environment variable as follow:
QUARTUS_ROOTDIR                    C:\intelFPGA\18.1\quartus
SOPC_KIT_NIOS2                         C:\intelFPGA\18.1\nios2eds
QSYS_ROOTDIR                            C:\intelFPGA\18.1\quartus\sopc_builder\bin
But I got this error:
Error No rule to make target DS5 uboot-socfpga.tar.gz needed by uboot-socfpga/.untar
What can I do ?
Thanks for your help
AnandRaj_S_Intel
This issue comes when using SOC EDS tool to generate the preloader. After creating the new HPS and BSP settings file, make command is giving a failure
Check below link:
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/embedded/2018/unable-to-make-preloader-in-windows-10.html
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
