17254 Discussions
Increasing the number of parallel cores to more than 16 in Quartus 21.2
anrfpga
Hi All,
We've been trying to run our designs on a server with 96 cores but the maximum number of cores the tool is using for fitting is not going beyond 16. Is there any way to increase it?
We selected the "Use all available processors" in the parallel processing settings under tools/options/processing but it did not help. We also tried adding "set_global_assignment -name NUM_PARALLEL_PROCESSORS ALL" to the .qsf file.
Nikhil
ShengN_Intel
For 21.2, the maximum number of cores the tool can use are 16 CPUs. Can't going beyond 16 CPUs check image below.
ShengN_Intel
anrfpga
Hmm. Sad that the tool cannot make use of the extra cores available. Now I have to wait 2 hours per run.
Nikhil
