17245 Discussions
Inference of DSP block with accumulator does not work
Geert
I'm trying to infer a DSP block with accumulator for Arria 10, using Quartus Prime 17.0.
The high-level functionality I need is:
if rising_edge(clk) then
  if sload = '1' then
      out <= a * b;
  else
      out <= out + a * b
  end if;
end if;
 I started from the template provided in Quartus: VHDL/Full Designs/Arithmetic/Signed Multiply-Accumulate, but this does not work: it uses a DSP block for the multiplier, but it does not use the accumulator function.
Instead, for small word sizes, it creates a loop back path via the second multiplier inputs to bring the output back to the adder.
When I increase the accumulator width to 48, the accumulator is implemented entirely in LUTs
Any ideas how to force use of the DSP block accumulator (preferably using inference) ?
Thanks, Geert
SengKok_L_Intel
Hi Greet,
If you are using an independent multiplier, could you please increase the input data width to >19 bits? If using lower than 18 bits, it will not fit into the hard accumulator.
Regards -SK Lim
Geert
Thanks for your answer.
I have tried with multiple different input sizes and indeed, 2x 16-bit multiplier inputs fails (accumulator is implemented in LUTs) , while with a 16-bit + a 24-bit input, I got the expected implementation (hard accumulator).
Could you explain what the exact criterion is? Is it the multiplier result that needs to have a minimal width, or is it just sufficient that one of the multiplier inputs is > 18 bits?
regards,
Geert
SengKok_L_Intel
I use the template below and change the width to 27, and it can fit the accumulator into the hard block. Perhaps, you may try to use the ALTERA_MULT_ADD to configure the accumulator to the mode that you needed.
Please refer to Table 25 for the accumulator function:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-10/a10_memory.pdf
// Quartus Prime Verilog Template
// Unsigned multiply-accumulate
module unsigned_multiply_accumulate
#(parameter WIDTH=27)
input clk, aclr, clken, sload,
input [WIDTH-1:0] dataa,
input [WIDTH-1:0] datab,
output reg [2*WIDTH-1:0] adder_out
// Declare registers and wires
reg [WIDTH-1:0] dataa_reg, datab_reg;
reg sload_reg;
reg [2*WIDTH-1:0] old_result;
wire [2*WIDTH-1:0] multa;
// Store the results of the operations on the current data
assign multa = dataa_reg * datab_reg;
// Store the value of the accumulation (or clear it)
always @ (adder_out, sload_reg)
begin
if (sload_reg)
old_result <= 0;
else
old_result <= adder_out;
end
// Clear or update data, as appropriate
always @ (posedge clk or posedge aclr)
begin
if (aclr)
begin
dataa_reg <= 0;
datab_reg <= 0;
sload_reg <= 0;
adder_out <= 0;
end
else if (clken)
begin
dataa_reg <= dataa;
datab_reg <= datab;
sload_reg <= sload;
adder_out <= old_result + multa;
end
end
endmodule
SengKok_L_Intel
If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
