17237 Discussions
Install of Quartus-pro-18.0.0.219-linux-complete on Ubuntu 18.04.1 LTS does not complete, it hangs
TMich2
  1. Quartus-pro-18.0.0.219-linux-complete$ ./setup_pro.sh
  2. accept all defaults
  3. Installing dialog completes unpacking files
  4. Installing dialog starts Quartus Prime Pro Edition Help..
  5. Another dialog appears Installing, Installation completed and does nothing.
Can use the cancel button, but why does not the install complete? Attached are screen shots of the dialog boxes.
Does all the features work in Linux? According to this link many features look like they are not supported in Linux https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/os-support.html
KhaiChein_Y_Intel
Can you try to install individually ?
Yes. Some of the software are not supported in some Linux OS. You have to refer to the link for details.
TMich2
Downloaded the lite version and had the same issues.
Then installed each component QuartusLiteSetup-18.0.0.614-linux.run, ModelSimSetup-18.0.0.614-linux.run,  QuartusHelpSetup-18.0.0.614-linux.run,
But, each one did not exit back to the shell, so control-C each one, to exit back to the shell.
Yes, QuartisLite did install and is functional (Have not tested it completely) Are the install files 32 bit?
TMich2
FYI:
tcmichals@VERITY-1171:~/intelFPGA_lite/18.0/quartus/bin$ ./quartus
(quartus:13465): Gtk-WARNING **: 11:01:14.986: Error loading theme icon 'window-close' for stock: Unable to load image-loading module: /usr/lib/x86_64-linux-gnu/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so: intelFPGA_lite/18.0/quartus/linux64/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /usr/lib/x86_64-linux-gnu/libicuuc.so.60)
/usr/lib/firefox/firefox: intelFPGA_lite/18.0/quartus/linux64/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /usr/lib/firefox/firefox)
Also, once Quartus Lite is running, there is an collision with the C++ libraries
~/intelFPGA_lite/18.0/quartus/linux64$ mv libstdc++.so libstdc++.so.old
~/intelFPGA_lite/18.0/quartus/linux64$ mv libstdc++.so.6 libstdc++.so.6.old
Now, firefox can when icons on the home is selected.
KhaiChein_Y_Intel
Upon checking, the Intel Quartus Prime software v18.0 is not supported in Ubuntu 18. The official supporting OS are listed in
XYZZZ
Were you able to successfully run Quartus with Ubuntu 18.04 despite errors?
