17249 Discussions
Instantiating VHDL entity in Systemverilog
I am trying to instantiate a VHDL entity in systemverilog. In the VHDL entity “iobits” is defined as follows.
iobits : inout std_logic_vector (67 downto 0);
because I am interfacing to a DE10_Nano to an external PCB that has lines connected out of sequential order compared to the GPIO lines that are expected, I need to connect the iobits to GPIO individually.
In systemverilog I have defined GPIO as
inout wire [35:0] GPIO_0,
inout wire [35:0] GPIO_1,
So I need to connect
iobits[0] to GPIO_0[16],
Iobits[1] to GPIO_0[17],
iobits[2] to GPIO_0[14],
etc.
I tried several different things but keep getting syntax errors.
Help!!!
Show your code and where you get syntax errors.
I am out of town for a week, so I can’t try compiling the code for a few days. I can post the original VHDL code I am trying to rewrite in Systemverilog. So what I am trying to find out is what is the comparable Systemverilog for the following VHDL.
entity DE10_Nano_FB_DB25 is
port (
--------- GPIO ---------
GPIO_0 : inout std_logic_vector(35 downto 0);
GPIO_1 : inout std_logic_vector(35 downto 0) );
end DE10_Nano_FB_DB25;
architecture arch of DE10_Nano_FB_DB25 is
HostMot2_inst : entity work.HostMot2_cfg
port map (
-- GPIO_0 -- DB25-P2
iobits( 0) => GPIO_0(16), -- PIN 1
iobits( 1) => GPIO_0(17), -- PIN 14
iobits( 2) => GPIO_0(14), -- PIN 2
iobits(34) => GPIO_1(16), -- PIN 1
iobits(35) => GPIO_1(17), -- PIN 14
iobits(36) => GPIO_1(14) -- PIN 2
end arch;
When I comment out this code the rest of it compiles without errors (but useless).
Thanks in advance.
Unlike VHDL, SV doesn't allow bit-selects in module instance port names. You can use the port name with a concatenation as port expression.
.iobits({GPIO_0(16),GPIO_0(17), ... })
Super! Thanks, when I get home I’ll try compiling it (and hopefully post success).
I have pasted in a section of code followed by the errors it generates. I edited in the line# 0402 to show where the errors start. I have attached the complete file in case the segment is insufficient.
HostMot2_cfg HostMot2_inst(
.ibus(hm_datai), // input [buswidth-1:0] ibus_sig
.obus(hm_datao), // output [buswidth-1:0] obus_sig
.addr(hm_address), // input [addrwidth-1:2] addr_sig -- addr => A(AddrWidth-1 downto 2),
.readstb(hm_read), // input readstb_sig
.writestb(hm_write), // input writestb_sig
.clklow(fpga_clk_50), // input clklow_sig -- PCI clock --> all
.clkmed(hm_clk_med), // input clkmed_sig -- Processor clock --> sserialwa, twiddle
.clkhigh(hm_clk_high), // input clkhigh_sig -- High speed clock --> most
.irq(irq), // output irq -- int => LINT, ---> PCI ?
.dreq(/* open */), // output dreq_sig
.demandmode(/* open */), // output demandmode_sig
.iobits( {
// GPIO_0 -- DB25-P2
0402 GPIO_0(17), // PIN 14
GPIO_0(14), // PIN 2
GPIO_0(15), // PIN 15
GPIO_0(12), // PIN 3
GPIO_0(13), // PIN 16
GPIO_0(10), // PIN 4
GPIO_0(11), // PIN 17
GPIO_0(08), // PIN 5
GPIO_0(09), // PIN 6
GPIO_0(06), // PIN 7
GPIO_0(07), // PIN 8
GPIO_0(04), // PIN 9
GPIO_0(05), // PIN 10
GPIO_0(02), // PIN 11
GPIO_0(03), // PIN 12
GPIO_0(00), // PIN 13
// GPIO_0 -- DB25-P3
GPIO_0(34), // PIN 1
GPIO_0(35), // PIN 14
GPIO_0(32), // PIN 2
GPIO_0(33), // PIN 15
// .leds[0](GPIO_0[01]), // output [ledcount-1:0] leds_sig -- leds => LEDS
// .leds[1](GPIO_0[19]),
// .leds[2](GPIO_1[01]),
// .leds[3](GPIO_1[19]),
.leds( { GPIO_0(01), // output [ledcount-1:0] leds_sig -- leds => LEDS
GPIO_0(19),
GPIO_1(01),
GPIO_1(19) } ),
.liobits(/* open */), // inout [lIOWidth-1:0] -- lhm2_iobits
.rates(/* open */) // output [4:0] rates_sig
endmodule
Error (10153): Verilog HDL Function Call or Function Declaration error at DE10_Nano_FB_DB25.sv(402): identifier "GPIO_0" is not a function File: /home/acondit/ArmProcs/mksocfpga/HW/QuartusProjects/DE10_Nano_FB_DB25/DE10_Nano_FB_DB25.sv Line: 402
Error (10153): Verilog HDL Function Call or Function Declaration error at DE10_Nano_FB_DB25.sv(403): identifier "GPIO_0" is not a function File: /home/acondit/ArmProcs/mksocfpga/HW/QuartusProjects/DE10_Nano_FB_DB25/DE10_Nano_FB_DB25.sv Line: 403
Error (10153): Verilog HDL Function Call or Function Declaration error at DE10_Nano_FB_DB25.sv(404): identifier "GPIO_0" is not a function File: /home/acondit/ArmProcs/mksocfpga/HW/QuartusProjects/DE10_Nano_FB_DB25/DE10_Nano_FB_DB25.sv Line: 404
Error (10153): Verilog HDL Function Call or Function Declaration error at DE10_Nano_FB_DB25.sv(405): identifier "GPIO_0" is not a function File: /home/acondit/ArmProcs/mksocfpga/HW/QuartusProjects/DE10_Nano_FB_DB25/DE10_Nano_FB_DB25.sv Line: 405
Error (10153): Verilog HDL Function Call or Function Declaration error at DE10_Nano_FB_DB25.sv(406): identifier "GPIO_0" is not a function File: /home/acondit/ArmProcs/mksocfpga/HW/QuartusProjects/DE10_Nano_FB_DB25/DE10_Nano_FB_DB25.sv Line: 406
Error (10153): Verilog HDL Function Call or Function Declaration error at DE10_Nano_FB_DB25.sv(407): identifier "GPIO_0" is not a function File: /home/acondit/ArmProcs/mksocfpga/HW/QuartusProjects/DE10_Nano_FB_DB25/DE10_Nano_FB_DB25.sv Line: 407
Error (10153): Verilog HDL Function Call or Function Declaration error at DE10_Nano_FB_DB25.sv(408): identifier "GPIO_0" is not a function File: /home/acondit/ArmProcs/mksocfpga/HW/QuartusProjects/DE10_Nano_FB_DB25/DE10_Nano_FB_DB25.sv Line: 408
Error (10153): Verilog HDL Function Call or Function Declaration error at DE10_Nano_FB_DB25.sv(409): identifier "GPIO_0" is not a function File: /home/acondit/ArmProcs/mksocfpga/HW/QuartusProjects/DE10_Nano_FB_DB25/DE10_Nano_FB_DB25.sv Line: 409
Error (10153): Verilog HDL Function Call or Function Declaration error at DE10_Nano_FB_DB25.sv(410): identifier "GPIO_0" is not a function File: /home/acondit/ArmProcs/mksocfpga/HW/QuartusProjects/DE10_Nano_FB_DB25/DE10_Nano_FB_DB25.sv Line: 410
Error (10153): Verilog HDL Function Call or Function Declaration error at DE10_Nano_FB_DB25.sv(411): identifier "GPIO_0" is not a function File: /home/acondit/ArmProcs/mksocfpga/HW/QuartusProjects/DE10_Nano_FB_DB25/DE10_Nano_FB_DB25.sv Line: 411
Error (10153): Verilog HDL Function Call or Function Declaration error at DE10_Nano_FB_DB25.sv(412): identifier "GPIO_0" is not a function File: /home/acondit/ArmProcs/mksocfpga/HW/QuartusProjects/DE10_Nano_FB_DB25/DE10_Nano_FB_DB25.sv Line: 412
Error (10153): Verilog HDL Function Call or Function Declaration error at DE10_Nano_FB_DB25.sv(413): identifier "GPIO_0" is not a function File: /home/acondit/ArmProcs/mksocfpga/HW/QuartusProjects/DE10_Nano_FB_DB25/DE10_Nano_FB_DB25.sv Line: 413
Error (10153): Verilog HDL Function Call or Function Declaration error at DE10_Nano_FB_DB25.sv(414): identifier "GPIO_0" is not a function File: /home/acondit/ArmProcs/mksocfpga/HW/QuartusProjects/DE10_Nano_FB_DB25/DE10_Nano_FB_DB25.sv Line: 414
Error (10153): Verilog HDL Function Call or Function Declaration error at DE10_Nano_FB_DB25.sv(415): identifier "GPIO_0" is not a function File: /home/acondit/ArmProcs/mksocfpga/HW/QuartusProjects/DE10_Nano_FB_DB25/DE10_Nano_FB_DB25.sv Line: 415
Error (10153): Verilog HDL Function Call or Function Declaration error at DE10_Nano_FB_DB25.sv(416): identifier "GPIO_0" is not a function File: /home/acondit/ArmProcs/mksocfpga/HW/QuartusProjects/DE10_Nano_FB_DB25/DE10_Nano_FB_DB25.sv Line: 416
Error (10153): Verilog HDL Function Call or Function Declaration error at DE10_Nano_FB_DB25.sv(417): identifier "GPIO_0" is not a function File: /home/acondit/ArmProcs/mksocfpga/HW/QuartusProjects/DE10_Nano_FB_DB25/DE10_Nano_FB_DB25.sv Line: 417
Error (10153): Verilog HDL Function Call or Function Declaration error at DE10_Nano_FB_DB25.sv(419): identifier "GPIO_0" is not a function File: /home/acondit/ArmProcs/mksocfpga/HW/QuartusProjects/DE10_Nano_FB_DB25/DE10_Nano_FB_DB25.sv Line: 419
Error (10153): Verilog HDL Function Call or Function Declaration error at DE10_Nano_FB_DB25.sv(420): identifier "GPIO_0" is not a function File: /home/acondit/ArmProcs/mksocfpga/HW/QuartusProjects/DE10_Nano_FB_DB25/DE10_Nano_FB_DB25.sv Line: 420
Error (10153): Verilog HDL Function Call or Function Declaration error at DE10_Nano_FB_DB25.sv(421): identifier "GPIO_0" is not a function File: /home/acondit/ArmProcs/mksocfpga/HW/QuartusProjects/DE10_Nano_FB_DB25/DE10_Nano_FB_DB25.sv Line: 421
--- Quote Start ---
--- Quote End ---
I changed
.iobits({GPIO_0(16),GPIO_0(17), ... }) to .iobits({GPIO_0[16],GPIO_0[17], ... }) and it gets rid of those errors.
So thanks for at least pointing me in the right direction.
Right of course, my fault. () is VHDL index syntax, [] is Verilog.
