17255 Discussions
Intel Quartus Prime(Lite Edition) unable to compile code
areebTAG
I am trying to compile& simulate VHDL code for a multibit adder along with its testbench. The code is tested in Questasim and it works fine however Questasim is giving errors which I can't quite figure out how to fix them.
If anyone knows how to fix these, that would really help.
My code and screenshots of the error is attached in this question.
sstrell
Those aren't errors, only warnings, so they should not prevent compilation in Quartus.
Your design is purely combinatorial, so that's why there's a warning about no clocks.
I don't know how you have your Quartus hierarchy set up, but you do not compile a testbench in Quartus.  That's only for simulation, so don't include the tb file in your Quartus project.
areebTAG
so what about if you wanted to simulate you code first using Questasim? Intel Quartus does the option for running a rtl simulation, correct?
sstrell
Quartus can generate script files so you can simulate in Questasim.  It doesn't do a simulation compilation.
ShengN_Intel
May I know any update?
areebTAG
yes its fixed by doing the pin planner
ShengN_Intel
Glad to hear that your issue has been resolved.
I'll now transition this thread to community support.
If you have a new question, feel free to open a new thread to get the support from Intel experts.
Thank you.
Sheng
